Tool Talk Discussion Forum
How to remove Armature of Generac Generator???
daniel gillespi
01-09-2008 19:10:27
Hi got a generac gen that engine needs new rings but cant get the armature off the shaft. it has a 10hp briggs on it
JT
01-10-2008 08:04:21
 Re: How to remove Armature of Generac Generator??? in reply to daniel gillespie, 01-09-2008 19:10:27
Daniel, This is going to freak you out, but to take the rotor off, take off the stator, get a block of wood, a big hammer, lay the block of wood on the side of the rotor where it is not plastcic and take the big hammer, and hit the block of wood so you are hitting the rotor sideways and it will pop off. If is a tapered shaft and a taper on the rotor, and when you hit is sideways, it will pop it off the taper.
Jim
Bob
01-09-2008 19:23:06
The engine shaft is tapered, and a long bolt draws the rotor snug over the end of the crankshaft.
Some have a thread in the ID of the far end of the rotor, so you can insert a long blank rod through the rotor, then screw the appropriate bolt into the end of the rotor, forcing against the rod, to force the rotor off of the crankshaft, much like a go-kart or snowmobile clutch is removed.
Have you removed the long bolt, and inspected the ID of the end of the rotor for threads?
