Tool Talk Discussion Forum
Lite-Rite Tester
Gary from Mules
01-07-2008 18:25:01
My boss ran across this tester today: Lite-Rite Floor & Equipment Tester 115 VAC Model A 10 Watts MFG. By W. E. Anderson, Inc. in KC MO.
has a red and a black lead that plugs in like the older style volt meter same ends on both end of leads. Meter reads from 5 Meg to 10 K.
The boss handed it to me and said figure out what this is. He hasn't a clue of anything that is for electricity. I have never seen anything like this. Can anyone help me out. I will post a picture in a few minutes.
deano
01-08-2008 13:06:10
 Re: Lite-Rite Tester in reply to Gary from Muleshoe, 01-07-2008 18:25:01
Looks like a megohmmeter (Megger)used in the electrical industry to measure high resistance values. Usually generates a relatively high voltage like 500V or 1500V. From the other descriptions sounds similar
Ralph - Ohio
01-07-2008 18:56:49
A Google search turned up the following information:
THE LITE RITE FLOOR AND
EQUIPMENT TESTER quickly
and easily measures the resistance of
conductive flooring and equipment
to minimize dangers of static elec
ticity in explosive potential oper
ating or anaesthetic locations. A
plate electrode is provided for use
in checking the conductivity of
anaesthetic machines, rubber goods,
floors and sheeting. Operates on
110 volt AC current.
MarkB_MI
01-07-2008 19:26:16
 Re: Lite-Rite Tester in reply to Ralph - Ohio, 01-07-2008 18:56:49
I haven't seen one of these units, but I've worked in electrostatic discharge (ESD) environments. The general idea is you don't want a dead short to ground, because of the risk of electrocution, but if the resistance to ground is too high you won't discharge static fast enough. I seem to recall that 100 kilohms is about ideal. Typically you have a static-safe mat on both your work surface and the floor, so both you and your work are protected from ESD.
Gary from Muleshoe
01-07-2008 18:38:28
third party image
Here is a picture of it.
