Tool Talk Discussion Forum
Powermate generator update
Mort Adella
01-07-2008 09:55:42
Upon VERY CLOSE inspection I found a faulty circuit board where the copper trace had not fully formed, leading to a solder joint failure of the exciter circuit.
I was able to scrape away some of the plastic overlay, clean up the posts, and remake the connections. It works now.
The picture is with Super MacroZoom digital camera and with plain old failing eyesight, the issue wasn't even imediately visible.
dave guest
01-07-2008 21:08:53
 Re: Powermate generator update in reply to Mort Adella, 01-07-2008 09:55:42
on circuit boards if foil is cracked try to bridge it with short piece of wire for best repair.
RayP(MI)
01-07-2008 15:39:47
Seen a bunch of solder joints like that in my time as an electronics technician. Seems that they escape the inspections with regularity.
Bob
01-07-2008 15:49:03
 Re: Powermate generator update in reply to RayP(MI), 01-07-2008 15:39:47
It doesn't look to me like it was defective, or missed inspection, It simply looks like the HUNDREDS of other cracked solder joints I have ssen over the years.
The connector pin expands/contracts at a different rate than the board/foil/solder 'til the joint fails.
Probably the single most common failure in modern electronic devices!
dlplost
01-07-2008 10:02:29
Excelent find. Some times the simplest things....
Mort Adella
01-07-2008 09:57:44
 PS, a great deal for $30 (nm) in reply to Mort Adella, 01-07-2008 09:55:42
no message
