Tool Talk Discussion Forum
Sparkplug testing
TGIN
01-07-2008 04:06:53
Can a sparkplug be bench tested with a multi-tester or some other ?? Seams like I remember my G`paw doing it but that was a long time ago , could have been a dream .
dave guest
01-07-2008 21:16:49
 Re: Sparkplug testing in reply to TGIN, 01-07-2008 04:06:53
thought the cut away view on champion plug used to show internal gap so they would have to read infinity. i am goin way back might be different now. tell me if i am wrong. when i can get out i will check some plugs
dave guest
01-09-2008 20:45:51
 Re: Sparkplug testing in reply to dave guest, 01-07-2008 21:16:49
Did check some plugs with meter. Five would show conductivity from terminal to center electrode. Five newer ones indicate probably an internal gap. The first group meter would check leakage as stated. The second group you cannot. Depends on the plug.
jack12345
01-07-2008 20:29:49
I forgot to mention that you can check for shorts(dirty plug) with the plug installed using a multi-meter set on high resistance.Remove plug wire set one lead on plug conductor and one to engine block if you get a reading-clean or replace plug.
jack12345
01-07-2008 20:21:15
I use a mult-meter to test all my plugs new and used.Picks up all types of problems such as hi resistance,opens & part shorts. If you want to save time and your arm check your small eng plugs with a meter.Had 2 NGK plugs for snowcat with open center conductor they were new.
dr.sportster
01-07-2008 13:44:07
Champion had a nice test stand like Ray is describing below.It had an air hookup on the side.I would love to have one and have never seen one at a swap meet or anywhere for sale.Same thing with those Stuveyent valve spring testers you put a torque wrench on.Never see them.In a two stroke plugs can really deceive.My test is change plugs.Not scientific or economical.I could probably electrocute myself trying a megger. A good magneto can give the plugs a test.If you have a cracked porcelin youll know it from the miss anyhow.
TGIN
01-07-2008 10:27:08
Thanks guys . Like I said thats been a long time ago . G,pa was a mechanic at the Olds garage and sales and G,ma drove a new one every year or two but G,pa drove a old studabaker pickup and I remember him pulling the plugs and cleaning them and I thought he was testing them also . He was full of answers but I was to young to ask the questions .
RayP(MI)
01-07-2008 08:39:34
Well, the old testers used to put the plug under air pressure (high as compressor would supply,) and then test them with high voltage. Viewer would allow you to see spark at plug tip. Problem with common test meters is that they deal with low voltage. Might find opens, or shorts, but not ones that are opened or shorted at high voltages.
IH2444
01-07-2008 07:31:19
You can probably test the resistor in the plug if resistor type or check continuity between the terminal and the electrde with a MM, but that will not tell you much since the meter is only putting out a very low voltage and spark voltage is 20KV or so.
