Stuck Spark Plugs on a Ford
ferg
07-29-2001 23:20:02
Just bought a "dealer" serviced Ford....has a spark plug froze in...seems rusted in...tried PB Blaster...cooling the plug....I heard heating the plug red-hot and cooling it might work?
Any suggestions before I pull the head?
Dan
08-02-2001 19:09:41
 Re: Stuck Spark Plugs on a Ford in reply to ferg, 07-29-2001 23:20:02
It's a FORD. Sell the damn thing. No, seriously.
Here's what I did: Get a hole saw (a GOOD one) the size of the outer diameter of the plug. (The ford seats on a taper, that is where it's stuck, and why you can't get the penetrating oil to the threads. Make a pilot for the hole saw that fits the inside of the plug (after you break it off trying to get it out) and suck the ceramic out with a shop vac) The pilot will keep the chips out of the cylinder while you saw/drill down to the head and remove the tapered part of the plug. (NO FURTHER) The threads remaining will come out fairly easily with a large screw extractor. Put a new plug in it, and buy a DODGE !!!! I bought a Ford once, NEVER AGAIN. Quality is job one, engineering is about #567.
BlueLite
08-04-2001 09:45:10
 Re: Re: Stuck Spark Plugs on a Ford in reply to Dan, 08-02-2001 19:09:41
Another possible, cross thread. If installed using a tool rather than by hand that's what happens sometimes and they usually won't tell the customer.
Branden
08-01-2001 18:17:50
I wouldn't try any of those tips. Go get some Marvel oil, 3 in 1. It comes in a little black and red can. I had a frozen engine where the pistons were rusted to the walls of the cylinders. A machinist told me to put some of that oil all around the edges and let it set overnight. I did, and the next day, it came apart ALOT easier.
Put some of that marvel oil around the edges, let it set overnight, and I would bet it will come out. Getting a little oil in there might foul your new plug when it burns off that oil, but, you can always repull it, clean it and reinstall. That's what I would do if it were mine. I would even try WD-40 before I would pull the head off or apply heat. One of these tips will work. Let us know what worked.
Branden
John Ne.
07-30-2001 20:44:06
One more thing, try removing the plug at operating temp, just in off the highway. Instead of cold and sitting. Seems to work on some of the new stuff. Also if its an aluminum head I have twisted off spark plugs in the head, the threaded area stuck tight, drill it out, used a reamer that came with a rethreader tap and helicoil, made it oversize, tapped it, put in helicoil, the plug, and ran the engine another 20k. Just get all the debris off the top of the piston. John in Nebr.
Dean
07-30-2001 06:24:16
If PB Blaster and tapping every so often with a tack hammer to set up a vibration to allow the PB Blaster to do its thing over a day or two doesn't work, you can heat the plug if you have good access to it and then cool it repeatedly. You don't have to get it red hot, just a little orange glow is fine. The "trick" is to do it many times. If that doesn't work, you can try to tighten the plug just a little and then back it off and then tighten again, and loosen again, etc.
The last two methods may harm the threads but the plug may be cross-threaded (lame mechanic with an impact wrench, no doubt) in which case you'll need to chase the threads when you finally get the plug out.
I've been using conductive anti-seize for years on plugs and most everything else and have never had one that was even hard to get loose, even after many years in the engine. For the anti-seize to work it must say that's it's conductive, the same type used on oxygen sensors. Permatex makes the one I use.
ferg
07-30-2001 10:04:03
 Re: Re: Stuck Spark Plugs on a Ford in reply to Dean, 07-30-2001 06:24:16
I tried PB Blaster for about a month....every night I would soak the seat with PB Blaster and tap the plug with a hammer (using a hardened piece of rolled steel to reach the seat). No luck. I even tried soaking the pug for a week using a cloth and foil to seal the Blaster in the plug hole.
I am concerned about the head...will the heat warp the cast iron head?
I am most angry with the dealer...this motor was serviced at the dealer...buyer beware I guess....
thanks for your advice...ferg
LarryG
08-10-2001 04:06:58
 Re: Re: Re: Stuck Spark Plugs on a Ford in reply to ferg, 07-30-2001 10:04:03
If the dealer is responsible for the situation, why not let HIM fix it?
Dean
07-30-2001 10:19:43
Not if you are careful. Try to heat the plug only and not the head. Use a small flame and keep it on the plug only. This is an ugly job so take your time and don't get in a hurry.
Given that you tried PB Blaster for over a month, I'm betting that the threads are crossed. If the heat/cool method doesn't work after say 10 cycles, I'm afraid you might just have to go to step #3 and tighten it a little and then back it out a little and then tighten a little and so on. This will almost certainly get the plug out but the threads in the head will almost as certainly be damaged. After you clean the threads up with a tap, try to install a new plug with some oil on the threads to see if you can get it installed to the torque specification, whatever it is. If so, great! If not, you will have to pull the head and take it to a machine shop for a decent repair. Let us know how it goes!
