Tool Talk Discussion Forum
Compressor
Harvey3
01-04-2008 16:23:07
I will be building a house in the spring, I bought a air framing nailer. I need a compressor, What is the minium HP and gallon capacity I should look for ?
Tks
Harvey
KEB1
01-04-2008 20:56:00
 Re: Compressor in reply to Harvey3, 01-04-2008 16:23:07
Nailers don't take much volume of air, but they do require 80 - 90 PSI. I've even successfully run mine on a small tankless compressor, you just have to give it a few seconds to build the pressure back up between shots.
If you're going to invest in a compressor you might think about what else you'd want to do with it. If its anything more than inflating tires, such as running air tools or painting, then that will determine how big a compressor you need.
Keith
glennster
01-04-2008 16:40:03
i use a little porter cable pancake compressor from home depot. it runs my nailers fine. its light, easy to carry and doesnt take much of a generator to run it if you are not near electric power. they usualy have em on sale and it comes with a brad nailer and a finish nailer for under 300 dollars. i have a bostitch 3 1-2 in framing nailer, and the lil compressor keeps up with it fine.
