Need help with Wisconsin engine
Denver
07-28-2001 17:00:38
I have an old Wisconsin engine, two cylinder model TFD, picked up at a sale. After dressing the points and installing new plugs there is very good spark. The fuel pump will not work. I bypassed the pump and gravity fed the carburetor. With a v-belt I hooked my rototiller to the wisconsin and spun it fast. It will spit raw gasoline out the exhaust but will not fire. Can anyone tell me what I have over looked. Timing maybe? How? Thanks, Denver
buck
07-28-2001 20:28:55
 Re: Need help with Wisconsin engine in reply to Denver, 07-28-2001 17:00:38
sounds like you may be flooding it. Remove the gas supply all together, remove the plugs and let it dry out put a little starting fluid in each cylinder,replace plugs and see if it fires, if it fires check the carb(jets float etc). Your gravity supply may be a little more than the old girl can handle untill you get it going good.
