Tool Talk Discussion Forum
PTO driven generator/welder?
Bob in Oakboro
01-02-2008 14:00:28
I am thinking about buying a PTO driven generator to use as an emergency backup if I ever need one. I was wondering if anyone makes one with a welder, as I could use one of those also, and this would give me a reason to hook up and run the generator more often. I have a 435 that produces about 35 HP.
Bill in IL
01-03-2008 10:03:01
 Re: PTO driven generator/welder? in reply to Bob in Oakboro, 01-02-2008 14:00:28
I like the idea of a PTO generator cause its one less engine I have to maintain I just use a tractor that I use every day. Probably a little less fuel friendly but how often do you really need one? The generator itself is almost maintenance free so no worries there.
Fawteen found you the link for what we all would like to have if we could afford it.
We have in the past used our PTO generator and buzz box welder strapped onto the cart to make a "poor mans" portable generator/welder.
buickanddeere
01-03-2008 14:11:39
 Re: PTO driven generator/welder? in reply to Bill in IL, 01-03-2008 10:03:01
I agree. The 435 should handle a 20-25kw alternator. If it's cold weather the 435 won't start without a block heater below 45-50F if it still has the old factory S type 17 to 1 pistons.
caterpillar guy
01-03-2008 08:11:41
Unless your going to be running things like bulk milk tanks or big electric motors a portable welder will run things in the house. You will need around 7-8,000 watts I know the refigerator doesn't need much juice but it will on start up just like the microwave and the deep freeze that is the reason for it and then you have the welder you want also. Generators are fine but just set around most of the time unless your out in the middle of nowhere.I have a miller welder with the Kubota diesel and it will rower the house if I don't try and run everthing at once.It is about 7or 8,000 watt continous.
Fawteen
01-02-2008 14:56:06
A quick google comes up with several. See the link. They appear to be a mite spendy...
135 Fan
01-03-2008 12:19:37
 Re: PTO driven generator/welder? in reply to Fawteen, 01-02-2008 14:56:06
Isn't solid state circuitry a really old term? I'd like to have a PTO welder, but I don't think I'd want one of those. They look kind of crude and are light. The nice thing with smaller portable welders is most of them have automatic idle which saves a lot of fuel. Dave
