Tool Talk Discussion Forum
Stove pipe/dampener ?
Super Steve
01-02-2008 06:35:58
We are putting a small wood stove in our shed and were wondering where to put the dampener in the pipe because we had to put a 45 right on top of the stove. Is it alright to put the dampener on an angle like that? The only vertical pipe we have is outside and it wouldnt be very much fun to go outside and change it all the time. Thanx in advance. Steve
Stan in Oly, WA
01-02-2008 09:39:31
 Re: Stove pipe/dampener ? in reply to Super Steve, 01-02-2008 06:35:58
Hi Steve,
I'm probably overstating the obvious, but if you have a choice of where to install the damper, don't forget to consider what it will be like to have to operate it when the stove is red hot.
All the best, Stan
Kemper
01-02-2008 06:46:01
The dampener will work fine at an angle.
Super Steve
01-02-2008 06:58:51
 Re: Stove pipe/dampener ? in reply to Kemper, 01-02-2008 06:46:01
ok Thanx Kemper, just thought i would ask before i did it. one other question is how far should the dampener be from the stove?
sojono
01-02-2008 07:56:13
 Re: Stove pipe/dampener ? in reply to Super Steve, 01-02-2008 06:58:51
the farther it is from stove more heat u will get from the pipes just as long u can reach the damper .
