Tool Talk Discussion Forum
Carb Cleaner
iowa_tire_guy
01-01-2008 19:08:01
Some time back there was a discussion here about using simple green for carb cleaner. I was a skeptic but was intrigued by not having to keep cleaner around for the very few times I use it. So today I tried it and it worked pretty good. I put a gallon bean can on the wood stove in the shop and had the water just steaming. Put in 1/2 cup simple green and let the carb perk in there for 45 minutes. When it came out the grease that was left was soft and wiped right off. Use compressed air to blow out the insides. I was impressed but that doesn't take too much.
Just another example of what you can learn here.
550Doug
01-02-2008 08:44:08
 Re: Carb Cleaner in reply to iowa_tire_guy, 01-01-2008 19:08:01
What is Simple Green and where do you get it?
iowa_tire_guy
01-04-2008 05:17:45
 Re: Carb Cleaner in reply to 550Doug, 01-02-2008 08:44:08
It's a household cleaner that comes in a gallon jug. Walmart, Dollar stores etc. Back in that section that men don't go too often.
Jerry/MT
01-01-2008 21:43:51
Thanks for the tip. How did the carb work once you installed it?
iowa_tire_guy
01-02-2008 04:41:30
 Re: Carb Cleaner in reply to Jerry/MT, 01-01-2008 21:43:51
Let you know today. Supper was called before I got it back together.
