Tool Talk Discussion Forum
Wisconsin V4
Tyler in CT
01-01-2008 11:09:35
I have a Wisconsin V4. I need to remove the flywheel. Are the crankshaft threads right or left hand?? Thanks
greygoat
01-11-2008 10:02:43
 Re: Wisconsin V4 in reply to Tyler in CT, 01-01-2008 11:09:35
I have a model VE4, 3 x 3 1/4 bore/stroke Wis.
4 cyl. The flywheel is deep dished so it's
hard to get a wrench on it. It takes 1 11/16
deep socket, and came right off with a 1/2
air impact. Righty tighty-lefty loosey.
DONT try to block the flywheel fins to keep it
from mooving. Cast Iron fins are VERY fragile,
and I broke 2. I was trying to make 1 good engine
from two bad ones, so had another flywheel.
Hard to find a 1 11/16 deep well socket. I got
mine, 6 point, from an industrial surplus place.
Crankshaft was too long for a regular socket.
greygoat
01-11-2008 10:06:43
 Re: Wisconsin V4 in reply to greygoat, 01-11-2008 10:02:43
After removing nut, hold top of flywheel with
1 hand. Hit end of crankshaft with a large
hammer, protected with a piece of wood.
Flywheel is on a tapered shaft, with a key.
It should "pop" right off with a hit or two.
shannon from ohio
01-01-2008 14:12:35
Right hand threads..
