Tool Talk Discussion Forum
HF Chainsaw sharpener
Bill in IL
01-01-2008 06:00:11
I am considering one of those 40 dollar Harbor Freight chainsaw sharpeners as an alternative to filing. Has anyone used one of these do they work good, great, ok or should I leave it in the store?
DiyDave
01-02-2008 16:11:52
 Re: HF Chainsaw sharpener in reply to Bill in IL, 01-01-2008 06:00:11
I think its on sale right now for $29.99. Like others have said, probably not bad for the money, I have had mine for about 2 years, be sure to dip the chain in solvent to remove oil, as the wheel gums up quick if you don't. Does a pretty good job for the money.
jeffcat
01-02-2008 08:58:09
A stupid thing to watch for is to MATCH the chain angles. Most chain is 20% degrees and make sure you set that for left and right cut. The chain will walk to the side the chain is cutting better on. The clamp on that machine is kind of cheep but it will work if you take care.
dlplost
01-01-2008 18:42:47
Have used mine for a couple of years now, works great, but like the others have said get some better wheels else ware. the one that came with it didn't last very long. Not shure but i think im using the oregon wheel also.
JT
01-01-2008 08:22:17
Bill,
As long s you are only sharpening a few chains a month (15-20), it should do you good. Don't buy their cheap sh$t wheels, buy an Oregon wheel, they will last you a life time. Bought their grinding wheels before, not worth taking home. Jst make sure you know what angles to use, some of the newer Oregon chains are using differant angles to make it cut right. Just make sure you can adjust it. Don't buy a fixed grinder. you will regret that. You also sharpen chisel chains differant than chipper chain. That is why angles are important on a chain grinder. It should be able to adjust 2 differant angles, 3 would be ideal!
Jim
supergrumpy
01-01-2008 08:26:18
 Re: HF Chainsaw sharpener in reply to JT, 01-01-2008 08:22:17
do you have a part # for Oregon wheel???
JT
01-02-2008 07:35:54
 Re: HF Chainsaw sharpener in reply to supergrumpy, 01-01-2008 08:26:18
Supergrumpy, Part number
1/8" thick 4 1/8" diameter 7/8" hole OR4125-18
3/16"thick 4 1/8" daimeter 7/8" hole OR4125-316
1/4" thick 4 1/8" diameter 7/8" hole OR4125-14
1/8" thick 5 3/4" diameter 7/8" hole OR533-18
3/16"thick 5 3/4" diameter 7/8" hole OR534-316
1/4" thick 5 3/4" diameter 7/8" hole OR534-14
5/16"thick 5 3/4" diameter 7/8" hole OR534-516
don't know the hole size on your grinder, but these are the Oregon wheels, you can make a bushing if your is smaller than these.
Jim
JT
01-01-2008 15:14:32
Not here, I am at home now, I will try to remember to check in the morning and let you know. I might need to know what diameter wheel yo need, the thickness, and the hole size, but I will see what I can find.
Jim
Bill in IL
01-01-2008 08:19:38
Yes I know what you mean about filing its hard to hold a consistent angle therefore its not as sharp.
I may just have to take advantage of the sale price on that. I seen the web sale price was 40 bucks.
Does this sharpener also do anything to take the rakers down? I just file them off a couple strokes every few sharpenings. Sometimes I get it right sometimes it gets a little too aggressive. How do you guys normally take them down?
El Toro
01-01-2008 07:57:03
With all the good responses you're received I would buy it. They had a pro type chain sharpener
where I worked and I used it for shapening my chains. Always seem to stay sharper than when I filed them. You miss all those fringe benefits when you retire. Hal
supergrumpy
01-01-2008 07:08:28
if you buy it, buy an extra grinding wheel $5.99
woodbutcher
01-01-2008 06:46:14
I've had mine about 6 months. So far, I like it. It has already saved money for me.
Butch
AZJIM
01-01-2008 06:07:25
We have one, works pretty good, have had it 5 years, need to sharpen chain about every hour cutting old seasoned mesquite, so it works for us Jim
Mokicker
01-01-2008 06:05:20
I've had one for couple years now and use it a lot: sharpen 6-8 chains every couple weeks. Have had absolutely no problems with it. Took a couple times messing up to figure out you have to pay attention and adjust settings for each chain, exclusively: like anything else mechanical. Will never go back to fileing unless in the woods and need a touchup right now.
carl
ldj
01-01-2008 06:48:55
 Re: HF Chainsaw sharpener in reply to Mokicker, 01-01-2008 06:05:20
Bill, I got one and I like it. If you serious about 1 Harbor Freight has it on sale for 29.99 ending 1/2/08
CH(upstate,NY)
01-01-2008 08:24:29
 Re: HF Chainsaw sharpener in reply to ldj, 01-01-2008 06:48:55
I looked on-line and saw $39.99. I'd like to pay the $10 less.
ldj
01-01-2008 10:33:29
 Re: HF Chainsaw sharpener in reply to CH(upstate,NY), 01-01-2008 08:24:29
Go here Link Both of these show it for 29.99. 1 ends 1/2/08, the other1/14/08
CH(upstate,NY)
01-01-2008 11:21:32
 Re: HF Chainsaw sharpener in reply to ldj, 01-01-2008 10:33:29
Thanks ldj.
