Tool Talk Discussion Forum
Lincoln 180 mig welder?
David Maddux
12-31-2007 18:06:21
I have miller 125 welder, I am not happy with it, I should have spent the money for a bigger 220 unit. Does anyone have any feedback on this Lincoln 180? On e-bay, they have a 180C and a 180T. I don't know what the difference is. But anyway thought I might get some ideas here.
135 Fan
01-01-2008 23:58:27
 Re: Lincoln 180 mig welder? in reply to David Maddux, 12-31-2007 18:06:21
You should be much happier with a 180 amp machine. Look on the Lincoln electric website for all the specs.. Like Stan said, one is probably a more deluxe unit. If the price difference isn't too big, I'd get the deluxe one. Either one should work well though. Dave
Stan in Oly, WA
01-01-2008 00:32:44
Hi David,
The previous generation of Lincoln wire-feed welders in that amperage range was the 175 amp units. The top of the line model had a dial that increases the heat like turning up the volume of a radio; the cheaper model had about eight fixed settings that would click into place. I suspect that's the difference in the models you named, too.
Stick welders also come in those configurations. The Lincoln buzz-box (tombstone) welder has fixed settings, while the equivalent Hobart Stickmate uses a crank handle to change the heat, which is referred to as an infinitely adjustable system. With stick welders neither system is clearly better than the other. What the fixed settings system gives up in precision, it makes up for in certainty---infinitely adjustable setting systems tend to creep during welding when the machines get older. I don't think there's a parallel benefit with fixed setting wire-feed welders, though. I think they're cheaper because they're not as good.
All the best, Stan
