Tool Talk Discussion Forum
What kind of pipe to use for air line?
unioncreek
12-31-2007 10:35:54
Someone gave me a 60 gallon air tank that I mounted my compressor and motor and and will locate to the loft in my barn. I'm going to run 1/2 inch line in the barn and 3/8 line for drop points. Can I use a 1/2 hydraulic hose from the compressor to the hard line? I also have access to all the 1/2 inch galvanized pipe I can use, but don't know if I should use it or 1/2 inch black pipe? Max pressure will be 150 pounds.
Any help appreciated.
Bob
Sean McDonnell
01-01-2008 15:29:23
 Re: What kind of pipe to use for air line? in reply to unioncreek, 12-31-2007 10:35:54
To address the PVC air line suggestion that was made....PVC piping should never be used for compressed air lines due to the fact that it can shatter if struck. If a PVC pipe cracks and fails under pressure it becomes a plastic grenade. There will be pieces of sharp plastic scattered all over your shop. I had a 1" PVC water line freeze and shatter a few years ago and trust me I'm glad I didn't get hit by any of those pieces and that was only @45psi.
marlowe
01-01-2008 16:28:32
 Re: What kind of pipe to use for air line? in reply to Sean McDonnell, 01-01-2008 15:29:23
BULL shi-
1030 brian
01-01-2008 18:38:53
 Re: What kind of pipe to use for air line? in reply to marlowe, 01-01-2008 16:28:32
He is right no PVC it is against OSHA also very dangerous under pressure. This has been brought up many times.
railhead
01-01-2008 18:31:06
you called it first
Hobo,NC
01-01-2008 14:24:22
Hyd or AC hose will work great from tank to supply line,,, I even use it on one compressor pump to tank,,, got caught in a jam when the cooper pipe flair cracked,,, worded so good just left it that way. Last compressor i hooked up I went to the local truck shop,,, he gave me a steel braided hose bout 2ft long that must B used on the air system on trucks cuzz he had quite a few of'em,,, don't remember the price may-b less than a 20
marlowe
01-01-2008 12:03:25
all my shops have PVC pipe schedule 40 good to 400+lbs use 11/2 or you will not get Enough air flow for big air tools like 1 inch impact wrenches you need big pipeing for good air flow 1/2 in. will not work
fixerupper
01-01-2008 11:26:51
Where do you live? If you live in a dry climate with 15 percent humidity or less, condensation won't be much of a problem and black pipe might work, but only as a second choice. If you live in the midwest or any other place where the humidity is up to 100 percent, galvanized or $$$copper are about the only way to go. Seems like the fittings (elbows, couplers etc.) will be the first part of the system to close up with rust.Jim
msb
01-01-2008 10:45:57
I would use copper and not worry about rusting pipes or flaking galvanize.T Bone gives the best advice. Slope the 3/4" or larger trunk line a little bit back to the compressor so any condensate will gradually make its way back to a water trap installed at the compressor along with drip legs at every 1/2"drop .I would go the next size larger on the connector hose to eliminate any concern about friction loss in a hose. My son installed aluminum snap together lines in his new body shop, a year ago, but I don't know anything aboutit other than he says the industry is going to.Says it is very easy and quick to install. Rust would be a non factor with aluminum too. I am surprized no one mentioned going the(no-no) PVC route. Maybe we are making progress in shop safety.
tiresntracks
01-01-2008 11:38:47
 Re: What kind of pipe to use for air line? in reply to msb, 01-01-2008 10:45:57
I just went and looked at a piece of schedule 40 PVC that I have. Its rated for 600 psi. Why can't you use it on an air system? Is it because of the glue or does oil from the compressor deteriorate the pipe?
David - OR
01-02-2008 07:57:41
 Re: What kind of pipe to use for air line? in reply to tiresntracks, 01-01-2008 11:38:47
PVC is not safe for air lines because it has a low energy of fracture (it is brittle). It has that property even when brand new.
Compressed air represents an enormous amount of stored energy. (That is the whole point of compressed air, after all, at least when using air tools). When PVC fails, that stored energy is released all at once, like a bomb. The PVC shatters into dangerous shrapnel and the shrapnel is propelled at high velocity by the explosive release of stored energy. You can demonstrate the shattering property for yourself by donning safety glasses and striking a small length of (non-pressurized) PVC pipe with a hammer.
PVC is safe and has a high pressure rating for pressurized LIQUIDS because liquid under pressure does not represent stored energy (liquids are not compressible). Should a pressurized PVC liquid line be struck by a vehicle, or whatever, it will still shatter, but the bits and pieces will not be propelled explosively around the room.
If the high price of copper and steel has you searching for an alternative, you might consider PEX-AL-PEX or similar polyethylene based plastics designed for pressurized gas service. These have a high energy of fracture and stretch or tear instead of shattering should they fail.
T_Bone
12-31-2007 19:16:35
Hi James,
That was a true statement before 1991 as after 1991 almost all gavlanzied is now electroplated thus will not flake.
Galvanized pipe is even now approved for gas piping as before it was not allowed for the same reason you stated. Hot dipped galvanized is still available but boy is it expensive and very seldom used.
All metal piping for air systems should contain 6" drip legs with take offs "T's" from the "top of pipe", slopped at 1/8"/ft (condensastion draining) with filters on drops as all metal piping will contain trash that will severely shorten tool life span if unfiltered air is used.
One inch main line is common with 1/2" drop lines for supplying volume on a typical home shop. If you have long runs with excessive demands then you won't be happy with smaller system piping. It's just like trying to shove too many amps thru a small wire. IT just won't work for long!
T_Bone
John in Ct
12-31-2007 18:41:00
I used copper and have been very happy!! So easy to just swett the joints. You can use hyd. line ( I did between the tank and main copper line) as long as it NEVER HAD A DROP of OIL IN IT if you want to avoide a potential problem if you want to use it for painting.
Buzzer
12-31-2007 18:22:14
I'd stick with the Galvanized. The water in the air will build up rust in black pipe which can break loose and get in your air tools. Black is specified for natural gas because the tiny bit of sulphur compounds in the gas react with the zinc in the galv.
335LP
12-31-2007 14:00:39
Save the galvanized for something else or sell to someone else. You just need black pipe and if done right so it drains well it will last for years with no problems. A few galvanized or brass fittings here and there is okay but you don't need galvanized pipe. Metal pipe helps cool the air so you can get the moisture out. Go to tptools.com and on left sidebar under tech notes and tips find a nice piping diagram that works well and explains why to use pipe. The extra moisture drops are well worth it the system and have done that to mine with 1/4" ball valves for drains.
JMS/.MN
12-31-2007 12:47:12
Using hydraulic hose to connect the compressor to the line is a good idea- flex takes care of vibration, and hose is easy to work with for setting up. Galv and black work equally well- black is cheaper around here. If the tank is in the loft- consider adding a drop pipe to the main level- to drain the tank. Likely to do it more often if it"s easily accessible.
jwal10
12-31-2007 11:52:18
We always use black iron pipe, galvanized can flake off....James
old
12-31-2007 11:47:48
Any good brand of pipe will have a rating on it and you want one thats is rated for twice your working load. I.E. if you plain to run it at 150 PSI you want pipe rated at no less then 300lbs. If you can't find what the pipe is rated at don't use it because it might blow up in your face.
tn terry t
12-31-2007 11:32:21
 Re: What kind of pipe to use for air line? in reply to dave guest, 12-31-2007 10:35:54
Ken Crisman said: (quoted from post at 11:43:14 12/31/07) Ya wanna run 3/4in galv. pipe from the compressor & then drop down to 1/2in for each opening with ball valves . Do not use black pipe for any air lines . Also install a drop behind each valve for draining water before it gets into the hoses . HTH ! God bless, Kens
just wondering why you would not run black pipe for air? i work for a major us company with plants all over the world we have industrial air compressors that run through 10 inch down to 1/2 BLACK pipe every plant i have ever seen run black pipe for air and gas. galv is only used for fluids aint trying start nuthin just wondering.
no such thing as too big of a air line i would and have ran no smaller than 3/4 for home shop air 3/8 hose is mighty small you can draw down a 3/8 air hose with a decent sized impact gun. dont get me wrong you can get by with 3/8 but if you can afford 1/2 hose you wont regret it
bill mart
12-31-2007 13:58:05
 Re: What kind of pipe to use for air line? in reply to tn terry t, 12-31-2007 11:32:21
Wouldn't the inherent moisture in the compressed air rust the black iron pipe?
Ken Crisman
12-31-2007 10:43:14
