Tool Talk Discussion Forum
Echo Chainsaws - Opinions?
Bill VA
12-29-2007 19:24:50
What are your opinions of Echo chainsaws?
I am considering one for some brush cutting. I need something durable as my Stihl's but lighter in weight.
Also, someone told me once that the Echo saws that are orange are professional grade and the white ones are consumer grades. Anything to that?
I am considering an Echo CS-306 (orange) and a CS-346 (white).
BTW, I am also considering a Stihl MS 200.
Any advice would be appreciated.
Thanks!
Bill
JT
12-31-2007 10:43:15
 Re: Echo Chainsaws - Opinions? in reply to Bill VA, 12-29-2007 19:24:50
In my opinion, if you are looking at a Echo and a Stihl, Other than a Dolmar, Echo in their respective sizes are better than a Stihl, hands down. they atart easy, are easier to work on, they don't use a special fuel line like Stihl that is expensive to buy, Their air filters are lower priced than Stihl. Buy an Echo, you will not be dissappointed.
Jim
Slowpoke
12-31-2007 00:37:52
I use an Echo 14" for most all trimming, liming, and felling. It's grey color, TOP HANDLE, light weight and a great saw. Not sure if it's a home owner or pro model.
Red Dave
12-30-2007 16:57:40
I have an Echo saw that I bought new in 1979 or '80. A 452VL, if I remember right. Only trouble I have ever had with it was the fuel line had to be replaced about 10 years ago.
I don't use it a lot, but it has always started right up whenever I needed it to run. Wore out the saw chains I got with it when I bought it and put a new chain on several years ago. Cuts like a new saw.
BTW, I used it for about 3 hours yesterday, started easy, ran strong.
supergrumpy
12-30-2007 12:35:41
I am clearing 29 acres of overgrown pasture, the 5 year project is going on 7 years already
bot Stihl MS180 with 14 inch bar first year and ran the bejesus out of it, with Stihl Micro-sized chain it only takes one stone and thats it, the thin chain really lets that tiny engine cut, real good on gas/oil, MS180 just about same as 170 but has handy chain tensioner
bot 2nd one 3 years ago, seems like its more "EPA-ized" than first one but still cuts great, I take both out in the bushes and cut till both are dull
both saws like to throw the chain cutting brush, converted one over to Bailey's "rim" sprocket and "Woodsman Pro" bar and chain and that helped a lot, same specs as Stihl chain but seems to take a lot more abuse before it dulls
I grind the depth gages way down, very little leverage cutting brush close to the ground so the extra bite helps
oh yeah, WEAR CHAPS, I have had too many close calls from working after getting over-tired
greygoat
12-30-2007 11:21:20
I've had a CS-306 chainsaw for 4 years, and have
gone through 3 chains, and the bar needs replacing now. I am cutting lots of brush,on a
Wisconsin State Natural Area. Always getting the nose into the sand, cutting close to the ground,
thus the bar wear. I can't give the ECHO enough
praise! It always starts, in any weather. I've
cut some 18 inch Maple and Hackberry, and some prairie Burr Oak that has so much silica in it
that you can see some sparks, in poor light. It
does the job, just slower in bigger stuff, and
it's light and easy to use for delimbing !
Roy Suomi
12-30-2007 10:12:37
I've recently bought a CS-346...What a nice saw..It starts on 2nd pull everytime..I'm completely sold on it..It beats the heck outa toting around my Homelite SXL-925 for average to smaller cutting..Very impressive cutting speed..We've got Stihls at work that don't cut as well..Plus....5 Year consumer warranty....I got mine on Ebay for around 175.00 with freight included..Mine came with 14" carvers bar instead of 16"bar..New ,never gassed up....Didn't even have to adjust carb..
tiresntracks
12-30-2007 09:15:34
I have an Echo 702EVL that I bought 30 years ago. It was heavy and underpowered compared to the Stihls, Huskys, and Pioneers of that time. I used it for years, and gave to my son a few years ago, and he still cuts wood with it. Everybody I know that has one of the new ones, likes them.
guido
12-30-2007 07:39:13
Hey Bill
I have a string trimmer echo since 1990.
I think I had to change the plug one time. It has been a work horse. Run it a couple hrs. at the time.
Guido
TomTex
12-30-2007 05:46:30
Echo is the BEST. My string trimmer, bought in 1998, is going strong. Tom
David - OR
12-30-2007 05:19:49
I bought a new Echo CS-346 from an ebay seller a while back. I wanted a lightweight saw for limbing (standing) trees and clearing brush. The saw works great for that -- much easier to handle for this work than horsing around a bigger saw, always starts reliably, idles smoothly and runs strong. I was so pleased with it that I bought an Echo string trimmer a couple months later.
2x4
12-29-2007 23:17:53
Echo is a good sturdy reliable saw
