Tool Talk Discussion Forum
IH F4 magneto
Nebraska Kirk
12-29-2007 10:23:29
Does anyone have any tips on how to remove the impluse coupling from an IH F4 magneto? I tried using a small gear puller but ended up breaking the coupler. I have a spare coupler but I have to remove it from a parts mag.
Earl - IL
12-30-2007 19:35:28
 Re: IH F4 magneto in reply to Nebraska Kirk, 12-29-2007 10:23:29
The thread is 9/16 -- 24 on my puller.
Nebraska Kirk
01-01-2008 15:46:09
 Re: IH F4 magneto in reply to Earl - IL, 12-30-2007 19:35:28
Thanks for the info fellows. I did see those internal threads in the impluse coupler, but since my 9/16NF tap would not thread into the piece of the coupler that I broke, I figured it was a non standard size. I gues I will have to see if I can have someone make me a puller.
dobber
12-30-2007 13:33:10
The puller is a special thread but can be made. Otherwise remove all the guts in front and drive shell and then after soaking press it out of the shaft carefully letting rotor go out the front but not far enough to let woodruff rip something.
Earl - IL
12-29-2007 18:54:11
It takes a puller to thread into the coupler with a screw in the center to push it off. I made mine yrs ago. I can check & see what thread that is.If you need to know. Earl in Illinois
Bob
12-29-2007 11:01:39
 Service Manual Link... in reply to Nebraska Kirk, 12-29-2007 10:23:29
I'm NOT an F-4 mag expert, but have you looked at the Blue Ribbon Mag Service Manual... it should be covered in there.
Here's a link to the manual, on the Rudi's Cubs Site.
You'll have to cut and paste, 'cause THIS site won't allow it to be posted as a "hot link".
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-5035%20Service%20Manual%20Magnetos/index.html
CNKS
12-29-2007 12:18:44
 Re: Service Manual Link... in reply to Bob, 12-29-2007 11:01:39
Or--
CNKS
12-29-2007 12:21:47
 Re: Service Manual Link... in reply to CNKS, 12-29-2007 12:18:44
Or -- You are correct -- some of that type link work, some don't. It did show on the preview page.
Bob
12-29-2007 12:25:00
 Re: Service Manual Link... in reply to CNKS, 12-29-2007 12:21:47
BTDT, over the last several years. The "cut and paste method" is the only thing that works with that link.
dobber
12-30-2007 13:35:57
 Re: Service Manual Link... in reply to Bob, 12-29-2007 12:25:00
Try these....
