Tool Talk Discussion Forum
W S-shape beam capacities.
Puddles
12-29-2007 04:17:25
I was wondering if any of you gentlemen might have a link or chart for lighter weight steel beams? I�ve been gathering charts and books for years, but they all seem to favor the heavier shapes. In my search yesterday I came across some software that uses Microsoft Excel to calculate loads for $35.00, but only allows input of beam sizes and weights for steel made in the UK, (United Kingdom)! The $35.00 is a steal if I knew their beams were the same thing as ours, it drives me crazy to convert from US to metric! I just bought some used W-12 x 16 and would like to know the load rating for an 8-foot span point loaded at one end. My �Ryerson Data Book� only goes down to W-12 x 26. Being retired now and only playing at the welding fabrication game I can�t justify paying hundreds of dollars for load calculating software. I just hate bothering all my engineer buddies for every little project I tackle. Thanks in advance for any help /information!
Chuck UR
12-30-2007 05:19:54
 Re: W S-shape beam capacities. in reply to Puddles, 12-29-2007 04:17:25
I hope you don't mind but since we're on the subject of beams I have a question.
I would like to add a 24' x 24' addition to my shop.
I'd like to build the framework with 6" x 6" x 3/16"
steel tubing that I have.
The two outer walls will be supported but I'd like the center beam to be 'freespan'.
The 3 beams will be tied together with 2" x 6" wood joists on 2' centers and the flat roof will be 5V 'tin'.
Will this work ?
or is the center beam gonna fall on my head ???
David - OR
12-29-2007 07:18:55
You can get wide flange beam section properties at the link below, among many other places.
The same website offers free beam bending calculators.
However, before you go building a crane out of one of these beams, ("8 foot span point loaded at one end"?) you need to understand the phenomenon of lateral-torsional buckling in steel beams. A W12x16 beam is a "tall floppy beam" with a short critical length -- it is intended to be use in a floor or wall type application where the compression flange is continuously braced.
With an 8 foot unbraced span, such beam is likely to twist or bend out of plane, and fail well below the load limit you would expect from classic beam bending equations.
Gun guru
12-29-2007 05:28:07
Try getting a Machinery handbook and look under deflection of loads.
Steve Andersen
12-29-2007 04:59:34
Try doin' a google search for "steel fabrication freeware" there isn't much you can't find.....even if you only have a vague description.
Have Fun
Steve
