Tool Talk Discussion Forum
whats a good power washer
ric1
12-28-2007 18:49:11
im looking to buy a pressure washer mainly to wash my vehicles in the drive instead of driving to the car wash that cost $3 to $4 dollars each time and also keep my masseys clean after a hard days work anyone know of a good unit thats not real pricey thanks RICK
buickanddeere
12-29-2007 20:30:46
 Re: whats a good power washer in reply to ric1, 12-28-2007 18:49:11
Something with a Comet or Cat three piston ceramic pump. And without a Chinese clone engine. Nobody ever bought too much pressure and volume when it comes to cleaning. With the good pump you can hook the pressure washer directly to your house or shop hot water tap. Once you use warm or hot water you will never willingly use cold water.
RayP(MI)
12-29-2007 16:33:48
I have one with a 5.5hp Honda. 2200psi, 3.5gpm. This is just about right for my use, which includes the things you mention. Will cut all but the worst burned on grease. The volume of water is as important as the pressure. Got mine for about $350 from Sam's Club a few years ago. Prices are much higher today.
Kent in KC
12-29-2007 06:44:42
I got a 1250 psi cold water unit that will knock the mud off tractors but doesn't do a very good job on cars. Be careful, you can take paint off pretty easy. To wash cars you really need hot soapy water. IMHO its hard to beat a decent commercial car wash. Besides, how many $5 car washes would it take to pay for a several hundred dollar pressure washer and all the soap? But, like I said, you can't beat them for tractors and farm equipment.
ric1
12-29-2007 06:07:19
thanks for all your input. 90% of the usage will be washing my service truck (just a pickup with a utility bed ) what maybe used 10/15 minuets a week/tractors once or twice a year oh yea the wifes car cant forget that one that wouldnt be good! thanks again for all your help definetly got me somewhere to start.THANKS RICK
Dick2
12-29-2007 05:44:05
I bought a Karcher, mainly for washing the truck. Pump housing broke on the first one. Karcher sent me another unit; it wouldn't work at all. They had problems with their GFI and sent me 5 units before I got one that worked. I've used it about 6 years now and it's hanging in there, but I wouldn't take any bets on how long it will last.
Brother got a cheap Harbor Freight electric that died in a short time. He took it back and they made him a swap deal for an engine unit with 2,400 psi that he really likes.
Mike M
12-29-2007 05:38:39
Those el-cheapo $100 ones will do as good or better than a car wash.
But if you want a REALLY good one buy a Hotsy ! Unlimited supply of hot water under pressure can't be beat. Pricey ,but should last a lifetime.
135 Fan
12-29-2007 14:41:20
 Re: whats a good power washer in reply to Mike M, 12-29-2007 05:38:39
A $100 pressure washer is not even close to a car wash. Most car washes are arond 1200 to 1500 PSI. Anymore could take paint off too easily if one wasn't careful. The biggest advantage a car wash has is the high pressure soap and hot water. Most pressure washers, even high pressure ones, use low pressure soap. It makes a huge difference. Higher pressure and/or heat makes up for it. Some good pumps like Cat can be set up for high pressure soap. A unit like a Hotsy works well because of really hot water. However if you look at the PSI on a Hotsy, you will see that it is lower than what you would think. The hot water (steam) is what makes the difference. A Hotsy type unit is expensive. Another thing to look at when considering a pressure washer, other than pressure, is the gallons per minute the pump puts out. Some cheap washers sound good because of the pressure but don't have enough GPM to take advantage of the pressure. It was explained to me that the pressure cleans the dirt off, but the GPM washes it away. Kind of like sandblasting. If you have more CFM, you can use a bigger nozzle and do the job a lot faster with the same pressure. Dave
Sean McDonnell
12-29-2007 05:22:42
Personally I'd steer claer of the campbell hausfeld models. I've had one for about 5 years and it's on it's third pump! The engine is a 6hp briggs which is fine. They are vertical shaft pumps and I've had nothing but trouble. The first pump failed after about 6 hours of use. The side of the pump housing cracked while I was in the middle of washing my truck! Just my 2 cents.
lucas boy
12-29-2007 04:59:48
red honda engine and cat pump has held up very well for us. lucas
Lee in Iowa
12-28-2007 21:34:47
I've had a northern hydraulics one with kawasaki engine for about 15 years and its been a good one the motor especially. It sits in a damp old cellar to keep from freezing and it always starts on the first pull. Lee
RobMD
12-28-2007 19:58:01
You're talking $6-700 for a good one. Electric pressure washers suck, IMHO. Mine was purchased at home depot for $649, and is under the dewalt brand. I'm sure excell made this washer. This is a 6.5 hp, 2800 psi washer that will work well for any application.
I've never found much use for a pressure washer after I bought one!
JT
12-28-2007 18:53:56
Troybilt or Briggs portable power products make a decent one. I have a cheap briggs I use at shop to wash lawnmowers, it gets a lot of use in the summer. They take some care to last a while. don't buy Karcher, or Powermate, they are the bottom of the cheap ones!
