Tool Talk Discussion Forum
Computer help
Dale B
12-26-2007 19:46:51
I have a new Dell 530s computer with Win XP At random intervals there is a "ding dong" sort of tone and the screen turns yellow, sometimes lite , other times dark. It will clear up by its self , also followed by a tone. I thought it was an alert for email , but that's not it . So far 3 of Dells tech's ( Vijay , Ashok , and Pavan )haven't been able to fix it, Anyone having similar problems ?? Any fixes I can relay to them ?
Ralph - Ohio
12-27-2007 05:17:38
 Re: Computer help in reply to Dale B, 12-26-2007 19:46:51
I had a similar problem with a Dell monitor several years ago. It turned out to be just the LCD flat panel monitor being automatically reset or re-calibrated. Sorry, I can't remember what the solution was but you might try a different monitor if you have one available.
Jim K
12-26-2007 20:47:57
Check your AC cord and be sure that it is plugged in properly at each end. Also you don't want a lot of stuff plugged in on one circuit.
It sounds like your machine is shutting down due to intermittent power loss or low voltage.
bihhl
12-26-2007 20:11:31
Another thought, are you loosing you internet connection??? Try unplugging youre internet connection to see if it does the same thing.
bihhl
12-26-2007 20:09:01
With xp can restore to an early date start>programs>accessories>sytem restore.
You can chose the date. Remember anything you have installed on the computer from that date forward will be lost
