Tool Talk Discussion Forum
LED Mini-Maglite
Fawteen
12-26-2007 14:06:41
I've had a "regular" mini-mag. Light level was okay at best, with new batteries, and it flat ATE batteries. So much so, in fact, that I quit using it because it was always dead when I needed it.
Decided to take a chance on the LED version. Haven't had it long enough to get a feel for battery life, but the light level is AMAZING. As much as my Double-D full size!
So far, I'm impressed.
Kent in KC
12-29-2007 06:52:16
 Laser too! in reply to Fawteen, 12-26-2007 14:06:41
I picked up one of those little LED flashlights the other day with a red laser in it as well ($15). A two position switch for light or laser. I'm going to machine up a bracket and mount it one my carbine so I'm ready when the UFOs land.
I also got a 3 million candlepower rechargeable spotlight from Orscheln that will light up a hillside a quarter mile away! 20 bucks!
Between my laser and floodlight my neighbors down the road don't know what the heck I'm up too but they're startin to wonder, I'm sure.
Little Ed
12-27-2007 19:32:39
 Re: LED Mini-Maglite in reply to Fawteen, 12-26-2007 14:06:41
YOU'VE GOT DOUBLE D'S????? ?? I always thought you was one of the fella's
135 Fan
12-27-2007 18:51:43
Sometimes there's no substitute for the "Double D" full size. LoL. Dave
RayP(MI)
12-26-2007 16:35:15
Almost by accident, son-in-law tripped over about the best small flashlights around. Brand name is "ELEMENT" and they're sold at Sam's club (I'm sure there are other retailers.) Is about 6" long, the diameter of a "C" cell. Actually powered by 3 AAA cells, has only 1 LED, but that sucker is bright! Have compared it to several multiple led units, and it outshines them all. Can't tell you how long batteries last, but I have only had a couple battery changes in the two years we have had them, and we own several, now. Would have to rate battery life as very good. Machined aluminum cases, and very well done. LED is in a parobolic reflector which is probably one of the reasons it does so well, where the multiple LED units can't put a well designed reflector around their LEDs. Mine has a rubber switch on the side, like Mag Lites, and it can be switched on easily when carried in a pocket. Newer models have the switch in the base, probably a better design. This little light won't match a multi-cell MAG LIGHT, but it does very well for itself, in closer confines, like working on machinery. I carry one for doing pre-dawn outside chores, etc. Does great, as long as you're not trying to spotlight deer, etc!
Dale in WV
12-26-2007 16:24:15
Guys if you want a lite that will really lite up the nite, theres an LED lite made by SureFire that will do the job. Got it as a Christmas gift last year. Not much bigger than a mini-mag, but packs a very bright punch. Enough lite to see if someone"s slinkin" around at 100 yards away. I"m a bit confused with the terminology of brightness when I try to compare lites. Some say lumens; some say watts. This one is just brighter than anything else you"d want to carry in your pocket. Oh -- don"t leave it on in your pants pocket -- or ask why.
Bob M
12-26-2007 14:59:15
I just installed a Mag Lite LED conversion lamp into my trusty old 3 x D-cell Maglite. Even with batteries that are nearly spent (would light the incandescent lamp only dull yellow...) the LED lamp is as bright as the old incandescent was with fresh batteries. I've since used it a couple hours - still with the spent batteries. The LED is as bright as ever.
So....I too am impressed. I may now just pick up one of those LED Mini-Mags to keep in my pocket...
Fawteen
12-26-2007 15:41:32
 Re: LED Mini-Maglite in reply to Bob M, 12-26-2007 14:59:15
That's good to hear, Bob.
I've gone through a half-dozen different options trying to find a light that will fit on my belt without being in the freakin' way all the time, or falling out of it's pouch every time I bend over, and still be bright enough to be useful.
The incandescent Mini-mag was the right size, with a nice holster, but I got tired of feeding it batteries REAL fast.
Hope this works out!
Hobo,NC
12-26-2007 18:14:48
 Re: LED Mini-Maglite in reply to Fawteen, 12-26-2007 15:41:32
I brought the LED conversion lamp kit for a mini mag that uses 2 AA batteries 10 bucks at lowes,,, may B the first mini mag i will ware out. I was look'n for some more bulbs and could not find them and saw the conversion to LED,,, The conversion paid for its self the first year,,, one set of bats no bulbs. I ware it every day,, comes off only to take a bath and sleep,,, takes a lick'n and keeps on tick'n,,, I am a haft blind auto mechanic,,,, It gits used i spec for a hour a day off and on,,, takes on concrete to. Now were do ya git a carrying pouch that will hold up,,, mine has tie straps holding it together.
T_Bone
12-27-2007 07:28:53
 Re: LED Mini-Maglite in reply to Hobo,NC, 12-26-2007 18:14:48
I too have joined the LED flashlite world with a 5w LED, that's right a 5w on a AA battery Mag-Lite mini-mag.
The LED is a TerraLux ministar extreme model #TLE-5EX, $25. The variable focus is retained. Comes with a new reflector. The LED has two lite beams at the same time. A wide angle 15ft diameter for night walking and a spot beam. I can stand on the back porch and see my shop doors 200ft away although the spot beam is getting weak at that distance. About 100ft is a good distance for this LED. You can not look into the LED lite as it hurts the eyes so it also has a tatical use rating for LE use.
Well worth the $25 as when I want to use a flashlight, I wanna see brite lite and this fills that requirement very well.
Another item I added was a end cap push-button switch with a strap. Well worth the $3.95 as the switch is heavy duty made, TeraLux M# TSC-1. I bought another brand of end cap push switch and it's not going to last long as it's cheap made.
My Mag-Lite rechargeable has the halogen bulbs. That was a noticeable improvement.
I also bought some lithium 1.5v AA battery's, the bunny, and will see how they hold up VS the Duracell photo grade lead acid battery's.
They also had Duracell AA 2500ah recharables for $10 for a pack of four. I'll see how they last.
I've given up on the standard Mag-Lite "D" size with recharable battery's as the lite is very dim when comparred too my Mag-Lite halogen rechargeable and I can't find decent lasting recharable "D" size 10000ah battery's. Out of 12 "D" size recharable battery's. I've had four failures in one year and the others are not far behind.
So I'm down to four flashlites, 2 Mag-Lite rechareables and two Mag-Lite mini-mag AA with LED and I've never been more pleased.
T_Bone
IH2444
12-27-2007 11:19:41
 Re: LED Mini-Maglite in reply to T_Bone, 12-27-2007 07:28:53
I use rechargeable batteries in my lights. The 2500 mah ones work almost as long as a new alkaline on each charge.
