trucker40
12-26-2007 19:06:20
Re: UPDATE NEW INFO---FULLELR TRANNY in reply to lenray, 12-26-2007 09:45:50
Well you learn something new every day.I never heard of a RT 613.Looks like its hooked to a DT466 or 3208 Cat,kind of a 13 speed for lower horsepower motors. Really do think you shift it like a 10 speed,and use 1,2,3 for real hard pulls.Its a deep reduction 13 speed.Highway trucks have the 13 gears on the top side so you can maintain your top speed easier,deep reduction has them on the low side to move big loads. Maybe the reason you are having trouble with the middle gears is that you start over in low gear on a 10 speed when you move your button? Its a fairly big jump from 5th to 7th if you skip 6th,you may not be able to get it in 7th. I saw how you listed it like a 10 speed. Otherwise theres a lot of things it could be.If there is something wrong with the transmission,most likely its with the air lines.The best thing to do is get a diagram of the air lines from Roadranger,Fuller,whatever they call it this week,and print it out.Crawl underneath and see if you can tell whether they are hooked like the diagram or not.If they are,I think there is a box bolted to the drivers side of the transmission,it has about 4 air lines going to it.You might be able to see it good by taking out the screws that hold in the shifter boot,slide it up on the shifter a ways.maybe hold it up with a tarp strap or wire. If somebody has worked on the transmission recently they could have dirt in a fitting,a mashed or kinked spaghetti line,or mashed ferrule on the spaghetti line that goes to that box on the side of the transmission.Or the spaghetti line may have not been put in tight enough and popped out of the fitting.You could be lucky and have different color lines to the block on the side of the transmission.I dont know how many lines it takes to shift it to the deep side,could just be one.It will go to the back of the transmission most likely.Look for it there and see what color it is,mabe black.One line is an exhaust line that will empty out under the floor,maybe just below the shift boot.The 2 others will go to the box on the side of the trans I was talking about.They could be red and white. If the truck has been setting for a long time,and whoever drove it didnt drain their air tanks a few times a week,that shifter box itself could be rusty inside,or wore out,and need rebuilt.Now thats a possibility,but dont mess with it unless it looks like all the lines are hooked up right.Quickest way to see may be take a line off(it will have 2 or 3 bigger lines besides the spaghetti shifter lines)hope it has a swivel on it,squirt some oil in it,put the line back on,build the air up to about 100 Psi AT least.With the motor shut off so you can hear, shift your button.You should hear a clunk when you do(trans has to be in nuetral).Thats a way you can be sure its in nuetral say if you have somebody underneath it adjusting the clutch.If you flip that button it should clunk. If it doesnt clunk,you say your low gears work,that eliminates the line that goes to the deep reduction,its allright.That only leaves the 2 on the box thats on the side of the trans.You can try and switch them.Maybe.Its probly that it has dirt in the line,mashed or kinked line,or mashed ferrule.There is other stuff it could be other than what I said here. If it dont look like any of this is what the problem is,post again,with as much info as you can about what you did,and maybe I can figure it out. You may just need to adjust the clutch or something.It could be a broken clutch brake.There is a clutch brake you can put in thats split that you can put in without taking out the transmission if you need to. It could be you dont know what you are doing. If you think its in the box on the side of the transmission,there are 4 bolts that hold that box on,they take a 7/16ths wrench.There is a little plnger or piston that goes from that box into the main transmission.Dont loose it,it has to go in the right way too,so remove it carefully so you can see how its in there.If you yank it off and it falls out,you cant tell how it was in there,find somebody to ask that can tell you.You dont want to spend all day pulling this box,putting it back on cause you had that plunger in wrong. This all sounds easy,but its not easy. If you find out thats whats wrong,you may be lucky enough to have a plate that bolts into the floor that you can take out and get to it a lot easier.You would need to take the rubber floor mat out to get it out,that could be hard,but maybe not if it was just taken out. If it has the old split top ferrules on the spaghetti lines they can be stuck in the fitting after you take the nut off,take a pair of sidecutters and real care full squeeze right at the bottom of the ferrule that you can see sticking out of the fitting,once you get ahold of it with the sidecutters,twist it a little and if you have air pressure it should come out easy.You could even just use a screwdriver if you get it in the right place and are carefull,push on the screwdriver and twist and the line will pop out.If its the wrong kind theres nothing to do but snip them off(after you mark where they go with tape)and put new ferrules in.You might be able to pull them out,but if you stretch the spaghetti line you will need to replace the stretched part of it or it wont work.
