Tool Talk Discussion Forum
Stihl 056 part 2
Ry
12-24-2007 12:17:04
Got back to work on the 056 that will idle but not rev up and runs rough. Wondering how much vaccum crankase should hold? I sealed it off and can not find that it is leaking anywhere. Also pulled the fuel tank off and see no problems with the fuel line or filter. Pulled the cylinder off to get a good look at the piston and rings - it all looks ok. As you know I cleaned and put a kit in the carb and took the muffler apart to check it but see no problems with it either. I am getting stumped but not giving up. Merry Christmas to all of you!
John - OH
12-26-2007 06:29:54
 Re: Stihl 056 part 2 in reply to Ry, 12-24-2007 12:17:04
Had a identical problem with a Stihl TS460. I replaced the coil and it fixed the problem. My vote would be replace the coil if everything else checks out.
jdemaris
12-25-2007 17:59:28
The standard Stihl test procedure for crankcase leaks is with pressure, not vacuum. I doubt it makes any difference, but instead of inche of mercury for a vacuum reading, the test specs are 7 PSI of pressure applied to the crankcase.
Usually, when a crankcase leaks, it's big leak and it's almost always from the big oil seal on the oil-pump worm-gear on the sprocket-side of the crankshaft.
In regard to the electronic igntion - there a few tests that can be done with an ohm-meter and capacitance meter, and the only thorough test requires a special test stand. In fact the Stihl manual gives some basics tests, and beyond that recommends replacing the ignition if suspected of being faulty. I've converted a few back to standard breaker-point ignition. You can hook a timing-light to it and see if the spark is crapping out when you rev it up.
Ry
12-25-2007 18:28:13
 Re: Stihl 056 part 2 in reply to jdemaris, 12-25-2007 17:59:28
I did put some pressure to it as well - about 5 psi. It seemed to hold it for a long time It still had pressure in it like 3 or 4 minutes later. I thought I found my problem today when I noticed the wire for the kill switch had a small bare spot in the insulation right close to the magneto coil. Soldered a new wire in its place put it back together and wala! still the same problem! I am noticing that when I pull the carb I hear what sounds like a release of suction?! Even if the saw sits for a day or two. Do not know why? Or if this is something to do with the problem. I am more stubborn than this saw and determined to find the problem! Thanks for your help JDemaris. It seems like there is a lot of mechanical knowledge on this forum.
Ry
12-24-2007 20:47:44
Is there any good way to check the ignition. I mean it obviosly has spark - it starts in a couple pulls - just runs bad. It has a new plug in it too.
