Tool Talk Discussion Forum
OT: road grader ball/socket ?
Dennis Minn
12-24-2007 08:49:34
I am looking to do some home-brewed engineering on my offroad vehicle and was looking towards a road grader ball/socket for articulation. Does anyone know what the real name of this component is? It looks like a steel ball that is caught between two bolt-together plates, which allows a lot of movement in a lot of directions. If you do know what I am trying to describe, where's a good source for one of these?
Thanks in advance,
Dennis
Rick Kr
12-24-2007 19:52:48
 Re: OT: road grader ball/socket ? in reply to Dennis Minn, 12-24-2007 08:49:34
Agree with Dutch, don"t know how big this project is, but a Heim joint would work the same and you can get them pretty big.
Or steal the end out of an 3 pt top link.
If all that isn"t big enough, then I figure you better call CAT, Komatsu, Deere, etc.
Good luck.
Rick
sam in mo
12-24-2007 13:46:06
At work my new JD 750 dozier with a 6 way blade has a hefty one on the blade, if you need a fairly big one.
Amarillo Doug
12-24-2007 12:08:17
You can get them at a Komatsu dealer.They are used on the Komatsu 530 graders (Same as the Galion850,850C)also on most of the older Galion graders
Old Dutch
12-24-2007 09:59:34
Dennis check out this, it should come up with what you are looking for. It is called a heim joint. Good luck OD
http://images.google.com/images?hl=en&q=heim+joints&btnG=Search+Images&gbv=2
Chris(WA)
12-24-2007 08:56:55
Ball and socket off a three point or a hydraulic cylinder? Where are you using it on the grader and what does it attach to? Most bearing supply houses have rod end ball and sockets in many sizes.
Dennis Minn
12-24-2007 10:14:48
 Re: OT: road grader ball/socket ? PICTURE (i hope) in reply to Chris(WA), 12-24-2007 08:56:55
third party image
I am quite unsure of the original purpose of the swivel style ball joint, I don't have a road grader. I will attempt to post what I had poorly described.
Thanks again,
Dennis
RJ-AZ
12-24-2007 12:15:16
 Re: OT: road grader ball/socket ? PICTURE (i hope) in reply to Dennis Minn, 12-24-2007 10:14:48
They are availabe through Caterpiller. Try the 120G aplication for the circle drawbar side shift cylinder. The one on the circle drawbar can be broken off and I have welded on a new one. As for the wrap arounds on the ball maybe use two halves and weld up whatever it is you need.
