Tool Talk Discussion Forum
Older Craftsman chainsaw
Max Door
12-24-2007 08:37:36
I lost the manual to this thing, and can't remember the oil mix ratio.
It is about 20 years old Craftsman, 3.7 / 18", red, heavy built.
Just hoping maybe someone here can tell me.
JT
12-25-2007 07:11:35
 Re: Older Craftsman chainsaw in reply to Max Door, 12-24-2007 08:37:36
Max,
If it a red one, probaly a Remington or Poulan, they wull use a 32:1 mix
tech4
12-24-2007 12:19:19
I have a 30 year old red Craftsman and the mix is 16-1 but I have other saws that use 32-1 and 50-1. I use the exact mix oil that works on all ratios from 1-1 to 50-1 and have had no problems. The 30 year old Craftsman still cuts as good today as when new. It has been hard to start from day one and still is but once going no problem. Quote on the oil
One-Mix and Exact-Mix Two-Cycle Oils
One way to eliminate several different containers
with different oil mix ratios is to use an exact-mix or onemix
two-cycle oil. These oils can be used in engines
requiring 1:1 to 50:1 mixes. A given amount of this oil
(usually 2.6 oz) is mixed with one gallon of gasoline and
can be used in any two-cycle engine which uses a mix
ratio of 1:1 to 50:1.
SP268I-2M-
Tom in TN
12-24-2007 12:18:28
Max,
I have an old Sears brand chainsaw that is about 20 or 25 years old. I haven't used it for about 5 years, but "it ran when I parked it".
Believe it or not, it uses a 16:1 mixture. I don't have a manual for it, but it has plate on the saw that specifies 16:1.
"Someday" I'm going to fire it back up.
Tom in TN
Chris(WA)
12-24-2007 09:15:15
My Craftsman uses 50-1 but many of my 2 strokers use 32-1 so I feed the craftsman that too. Figure a little more oil won't harm it. Have to clean the plug ever onece in a great while.
