Tool Talk Discussion Forum
wood stove damper
Roy Suomi
12-23-2007 17:40:05
I've got a Riteway 37 for primary heat in my pole barn..It's got it's own damper system built in to the stove..should I install a damper into the stovepipe in addition to the one built in..I've found that when I open'er up to roar a little for a faster warm-up, that the stove seems to pull air[oxygen] from the masonry thimble area and won't settle down for a few minutes when I close off the ashdrawer air supply.. I've got a 22' block chimney with an 8X8 flue liner..Otherwise it works good..Thanks. Roy
36 coupe
12-24-2007 02:14:37
 Re: wood stove damper in reply to Roy Suomi, 12-23-2007 17:40:05
Ive been using a Riteway 37 for 40 years now.You need a damper in the stove pipe.Thats not a damper in side the stove,its a baffle by pass that makes it easier to get the stove started.This stove will run wild without a pipe damper.My chimny is about 14 feet.Make sure the damper plate locks firmly to the spindle.
mph
12-23-2007 19:37:31
Not in the chimney but in the smoke pipe leading to it!
jdemaris
12-23-2007 18:29:20
I wouldn't have it without a separate damper in the chimney. That way, if the chimney ever catches fire, you can choke it with the damper.
You can't always rely on the one built into the stove.
RobMD
12-23-2007 21:12:26
 Re: wood stove damper in reply to jdemaris, 12-23-2007 18:29:20
That's why you keep a chimney clean. The less creosote buildup, the less heat maintained in the chimney.
jdemaris
12-24-2007 08:17:31
 Re: wood stove damper in reply to RobMD, 12-23-2007 21:12:26
Yes, sounds very good in theory.
And to be technical, the better built chimney, the MORE heat it retains which helps to keep it clean. Cool chimneys are the real fire hazzards since they get coated with creosote very fast, even with good hardwood with only 15% moisture.
Most chimney fires start from chimneys that have been run too cool, too long, and then get a flash from a hot fire. That's also why the so-called "air-tight" degign was a fad in the 70s that got dropped after the many fires it led to.
Sounds to me like you've never heated a home completely with wood, all winter, in temps that can vary from plus 40F to minus 35 F. It's not feasible to run a wood-furnace constantly at optimum stack-temps for the least creosote all the time. If you did, the house would get too hot on not-very-cold days. If you're playing with a smaller woodstove as a heat supplement, that's a whole different story. It's also not likely that someone is going to clean their chimney every day. So - in my opinion and experience, a fire-proof chimney, and a good shut-off damper in that chimney is very important for saftey-reasons. I've heated entirely with wood for 40 years and never had a fire. I have, intentionally started controlled chimney fires - it's a good way to get a chimney clean if you know what you're doing (and the chimney is metal, not clay or brick).
supergrumpy
12-25-2007 07:52:39
 Re: wood stove damper in reply to jdemaris, 12-24-2007 08:17:31
my uncle Joe used to clean his chimney by burning it out, just remove the stovepipe and toss in some burning newspaper
my BIL is Fire Chief and he nearly had heart attacks whenever Uncle Joe did that, 150 year old masonry chimney probably full of holes
he never burned the house down but fire sure roared up the chimney, I use a brush
36 coupe
12-26-2007 03:09:10
 Re: wood stove damper in reply to supergrumpy, 12-25-2007 07:52:39
If he had ever seen liquid burning creosote running out of bad masonary joints he would have stopped doing that.
