Tool Talk Discussion Forum
gasoline welding torch
ldj
12-23-2007 07:15:33
Anyone know anything about a welding torch that uses gasoline instead of acetylene as the fuel. I run google search and came up with little and no prices. Heck, first hand info. is better anyway.
L.D.
T_Bone
12-25-2007 06:37:00
 Re: gasoline welding torch in reply to ldj, 12-23-2007 07:15:33
Hi LD,
gasoline/Oxy will have theroretical flame temperature close too Mapp/Oxy. To increase the output BTU then adding 10% alcohol should work well as increasing the orifice size for gas welding.
Although it will be close, there's no known subsitute for Acet/Oxy for gas welding.
One could use a Coleman camp stove generator or lamp for a "gas" source. I can't see paying the $700 bucks in parts.
Gasoline vapor will use about 90% less volume than acetylene to accomplish the same job for heating. Overall efficientcy will be less than Acetylene tho.
Merry Christmas
T_Bone
Stan in Oly, WA
12-23-2007 10:22:43
Hi L.D.
I've heard of oxy/gasoline cutting torches, but I don't remember ever hearing them described as welding torches. None of the other fuel gases except for acetylene produces enough heat for welding, but most of them allow brazing. Without specific information about the amount of heat gasoline produces, I'd be inclined to suspect that it might not qualify as a welding gas either. If welding is a requirement of your selection, be sure to find out if gasoline will do it. As several others have already mentioned, oxy/gasoline setups aren't cheap.
Merry Christmas, Stan
husky
12-23-2007 09:37:21
saw them in farm show mag. very nice worked extremely well. cuts thick stuff(metal) very expensive as i remember about $$600.00-700.00
thejdman01
12-23-2007 07:26:06
Your looking for a petrogen google that. They are awsome, worth every penny
Bill in IL
12-23-2007 08:25:58
 Re: gasoline welding torch in reply to thejdman01, 12-23-2007 07:26:06
How much does one of these cost, any idea?
ldj
12-23-2007 07:44:33
Looks good but doesn't say anything about welding or brazing.
Jon Hagen
12-23-2007 22:04:34
 Re: gasoline welding torch in reply to ldj, 12-23-2007 07:44:33
I have a relative that uses several Petrogen brand gasoline torches in his rigging business, They are an amazing cutting machine, but no good for welding.
Jon Hagen
12-23-2007 22:09:59
 Re: gasoline welding torch in reply to Jon Hagen, 12-23-2007 22:04:34
Forgot to add that he is allowed to use the gasoline/ox torch where acetelene storage and use is forbidden, and fuel is as near as the closest gas station. Says they can cut all day on a couple gallons of unleaded regular.
