Hi LC, What the tech was using is Ultrsonic testing and yes I agree that UT is alot better than DP or MP. Both DP and MP only check for discontinuity's with-in 1/16" of the surface. A deeper problem would not show up with either of these two NDT methods. UT then would be the next best as the UT sound waves travel the full metal thickness. The problem here is that were open to discussion of just what the scope reads. A "very" experienced tech would be a asset in this case. I don't know if the newer UT scopes have a memory function to where the data could be reviewed by a metallurgist or welding engineer at a latter time. X-ray NDT is always #1 when it comes to 100% metal thickness testing as there is a film that can be seen by many experts in that field. Back in the days, only a field engineer could make the call if there appeared to be a problem and only then would a metallurgist/welding engineer be called to the field for final determination of the flim. The testing company is taking a huge risk by letting a field engineer make that call! As a AWS/CWI, I always liked going to the field to look at the films as it got me out from behind the desk. :) T_Bone
