Tool Talk Discussion Forum
Setting anchor bolts correctly
Stan in Oly, WA
12-19-2007 17:39:32
I have to set anchor bolts in a 6" concrete wall. They are the kind with a short taper on the end that goes in the wall and a moveable sleeve that is expanded by the tapered end as the tightening of the nut begins to withdraw the bolt. The bolts will have to withstand more tension than shear, but some of both forces. Is there a best depth to drill the holes in the wall? I have 5" anchor bolts but I have to buy more so I can get whatever length would be best. I can set the stop on the roto-hammer so that I can drill whatever depth hole would be best. If I were setting them in epoxy I would think that deeper was better. With expansion anchors I don't know.
Stan
Slowpoke
12-22-2007 21:26:12
 Re: Setting anchor bolts correctly in reply to Stan in Oly, WA, 12-19-2007 17:39:32
Did you look into using Titan HD bolts as mentioned in a previous post? Drill the hole to the recommended depth and wrench it in. Go to the Simpson web site and see what force it will take to pull them out, compared to epoxy. I purchased Hilti epoxy and a gun for securing bottom plates on carport walls, but the engineer specified Titan HD bolts even tho I told him I had the epoxy.
jd720ga
12-21-2007 18:11:54
They lost some celing tiles in the big dig in Boston's big dig tunnel due to epoxy failure.
suptscottyb
12-20-2007 18:59:14
Stan, you didn't really specify what kind of loads or torque was to be applied. There is no doubt that epoxy out does mechanical anchors. Just depends on how strong or perminent you want to be. The anchor bolts are subjuct to deterioration by rust etc. because, unlike epoxy, there is air and moisture getting to them. Good luck.
Chris(WA)
12-19-2007 22:29:00
Yes, because if the hole is too deep the epoxy will not mix. Just gets pushed into the bottom of the hole. There are good directions with the kit and on Hilti's website. If you are using wedge anchors the hole can be very deep or even perforate the slab. I have done that in places where I knew the anchor would end up damaged or have to be cut off to remove the mounted equipment soon. Then I would just drive the old bolt out the bottom of the hole and drive a new one in.
RobMD
12-19-2007 19:37:32
www.hilti.com
Gerald J.
12-19-2007 18:19:32
Find out who made those anchors and go to their web page for detailed instruction. Each is a little different. You often want them deep so they don't pull out a plug of concrete.
Gerald J.
El Toro
12-19-2007 17:57:06
We used anchor bolts for securing a big bedplate to the concrete floor. You drilled a hole in the concrete to fit the size of the anchor bolt and then you dropped a container of an epoxy adhesive into the hole then drove the anchor bolt into the hole sqeezing out that epoxy. Once it dried you couldn't move the anchor bolts. Take a look at this web site. We had problems with the anchor bolts you are describing becoming loose. Hal
Link
PS: These won't come loose.
Stan in Oly, WA
12-19-2007 18:18:35
 Re: Setting anchor bolts correctly in reply to El Toro, 12-19-2007 17:57:06
Thanks Hal,
In my heart I know that's what I ought to do. My boss told me the same thing you said. He was skeptical about epoxy until he tried it and gave it the BF hammer test. Now he's a believer, as well as an old dog who's learned a new trick.
Does the depth of the hole make a difference with epoxy?
Merry Christmas, Stan
El Toro
12-20-2007 03:42:38
 Re: Setting anchor bolts correctly in reply to Stan in Oly, WA, 12-19-2007 18:18:35
We not only used them, I saw some being used on "This Ole House" show that use to be on Home & Garden Channel. The reruns were better than what they have on now. Hal
PS: Its been 20 years since those anchors were installed. I will call the man that took over for me when I retired and see if they have had any problems with the anchors. I doubt it.
