Air jack off of CO2
Mike
07-23-2001 18:05:00
I'm an amateur offroad racer and am interested in getting an airbottle jack. Has anyone ever used these with CO2 instead of a compressor? I have onboard CO2 for quick tire fills and to reseat lost beads and would like to use it for the airjack as well. ONly problem I see is that the CO2 I can only carry upto 150 psi and some air jacks (for 12 tons) go to 200 psi. If all I need is about 3 tons lift power, do you think that 150 psi would work?
Thanks - I don't know where else to ask.
Mike
Tyler(WA)
07-24-2001 07:43:15
 Re: Air jack off of CO2 in reply to Mike, 07-23-2001 18:05:00
I agree with FRED. Nitrogen isn't corrosive to wiring or other metal like CO2 is. You might also try a SCUBA tank. There are adapters already made for doing just that and they hold about 100 cubic feet of air. Cheaper to fill too.
FRED
07-23-2001 19:06:51
Switch your on board suply to dry nitrgen and use a regulator. FRED
Duallie
07-27-2001 01:01:47
 Re: Re: Air jack off of CO2 in reply to FRED, 07-23-2001 19:06:51
He's using co2 because its available in liquid form in a bottle without a siphon tube. Liquid co2 in a 20 pound bottle will fill at least 3 DOZEN tires while a 20 lb bottle of nitrogen might fill TWO flat tires.
