Tool Talk Discussion Forum
My first big compressor.
Stumpalump
12-17-2007 08:48:45
I just picked up a Devilbiss 80 galon compressor.
It came without a regulator. Do I just pick up a regulator at home depot and plumb it on to the tank output? What about the lubricator kind. I'm thinking I dont want my lines full of oil and I'm good at adding lube to my tools. How much oil do these thing wind up putting in tires? How about when you use a blow gun? Do they spray oil?
The regulators I've seen say 160PSI but my compressor is 175psi. Is that OK? I'm going to Home depot today to get a 50amp plug but should I go elseware for a regulator? Any advise or set up tips appreciated.
guido
12-18-2007 12:57:28
 Re: My first big compressor. in reply to Stumpalump, 12-17-2007 08:48:45
Hey stumpalump.
If you look at your air tools specification you will see that they are rated at 90 p.s.i., as long the volume is there your tools will work fine. They will produce more with higher pressures but it is usually not needed. Your 80 gallon tank should have plenty of volume. You can dedicate a line to lube your tools, or do it manually, before and after each use. They need to be lubed after so as they sit won't rust.
Guido.
335LP
12-18-2007 12:22:42
Go to tptools.com and on left side bar check out tips & tech notes to find this plumbing chart and air consumption chart to help. Like others said you want a dedicated line for air tools only if you want to use a oiler and same goes for air hose. Don't want to use air hose with oil in it for painting. Once you get oil inside the hose it's there forever. You can always mount the oiler with snap couplers too to just use with air tool hose when and where you need it. You'll get more moisture out by mounting the moisture filter farther downline away from compressor where air is cooler and by putting some slope on pipe to drain out to end. The extra pipe and valves for the water traps on ends are worth it and have kept my lines in use for over 20 years now. The chart tells you why metal piping works better than plastic too.
glennster
12-17-2007 17:03:03
dont put the oiler in the main lines. you will never be able to paint with the compressor, oil vapor will always be in the lines. i like to use a 3 ft hose whip with an inline oiler just before the air tool if you are doing a lot of work. if occasional use, like the other guys said, couple drops of oil in the tool. you can mount your filters, water traps and regulators at the end of the run. if you have multiple outlets, use milton couplers and you can move the set up where ever you need it. be sure to crack the water drain at the end of the day to drain any water out of the compressor tank, or, i leave mine open just a tad so any moisture drips out, there will be a barely audible hiss of air coming from the fitting
Charles (in GA)
12-17-2007 16:54:47
www.surpluscenter.com
Good deals on things such as regulators, if they have what you need.
Charles
markiz41
12-17-2007 11:15:24
Plumb about 20 feet of at least 3/4 pipe before you put any accessories on. Plumb in a filter/water trap before the regulator. Don't add an oiler unless you plan to dedicate the line to oiled tools. Do what RickL does - put a few drops of oil in the inlet before using a tool. You will very rarely need more than 100 psi in the line, so 160 psi reg will suffice, just make sure it's rated for the 175 psi inlet (it will be).
RickL
12-17-2007 10:39:34
run two 80 gal tanks tied together for over 25 years only time use regulator is painting and brad nailers. everything else direct out of compressor. oil tools by themselves and have never had problem most of my tools are twenty some years or older also. all cp air brand tools. keep it drain of water is whats important. Iremove drain petcocks on tank bottoms replace with air hose use it to sourse out side shop air and it takes moisture out when use it also. All lines plumbed in shop are steel pipe with moisture drops,no oilers or regularoes installed . I f Ineed regulator it is snap coupled in when need only
