Tool Talk Discussion Forum
JD snow thrower issue
Matt W
12-16-2007 14:17:57
Hi,
I have a John Deere 318 yard tractor and a JD 49 Snowthrower. I hit a rock this morning and instead of breaking a shear pin, something else gave way.
On the snowthrower, Does anyone know how the primary chain sproket for the auguer system is attached to the drive shaft? Something broke at that point and I'm looking for the fix. It looks like it was welded there. Is that correct or no?? Appreciate help. Thanks.
Robert Huntress
12-16-2007 14:57:10
 Re: JD snow thrower issue in reply to Matt W, 12-16-2007 14:17:57
The snow thrower has a bolt in the outer end of the auger, which the dealer informed me was the shear point. I wanted to replace this bolt to a roll pin, but as it was a government owned peice of equipment, I had to simply replace it with a new "factory original" bolt.You should see one one each end of the auger.
Bob
12-16-2007 15:25:25
 Re: JD snow thrower issue in reply to Robert Huntress, 12-16-2007 14:57:10
It has ONE shearbolt, Key #6, at the RH side of the auger:
Third Party Image
Robert Huntress
12-16-2007 20:47:06
 Re: JD snow thrower issue in reply to Bob, 12-16-2007 15:25:25
The model that we had in Buffalo had one on each side, but it could have been a different JD model. The Coast Guard's snow thrower recieved PTO power at a gear box which sent the power to both sides of the unitwhich drove the auger via a chain and cog. Each side was actually independent, and when a shear bolt sheared, the opposite side continued to operate. This made trouble shooting pretty obvious.
Bob
12-16-2007 14:29:19
Yep, the haft and sproket are sold as one piece, and appear to be welded together.
Third Party Image
At least, you didn't break the gearcase, like I did some years ago!
RayP(MI)
12-16-2007 16:49:08
 Re: JD snow thrower issue in reply to Bob, 12-16-2007 14:29:19
Yeah, Bob those gearboxes ain't cheap... ask how I know!
Matt W
12-16-2007 17:46:11
 Re: JD snow thrower issue in reply to RayP(MI), 12-16-2007 16:49:08
Thank you Very Much Gentlemen!
