Tool Talk Discussion Forum
Diesel Injector Tester
Jeff NwOH
12-16-2007 09:09:59
Went "shopping" at the local scrap yard the other day and left with 2 of these. Kent-Moore diesel injector nozzle testers. Looks to be just a resivoir with a hand pump, 5000# guage, and a couple knobs for pressure relief and one for fine adjustment. I assume you can check the opening pressure of the injector, but do these pump enough volume to check spray patterns too? As I probably don't need 2 are they worth anything? Poked around the internet but couldn't find anything quite like these. Did not get the misc adapters to connect to injectors, but one tester looks to never have been used. Would have been kind of cool to have one when I had my JD R apart.
Robert Huntress
12-16-2007 15:14:56
 Re: Diesel Injector Tester in reply to Jeff NwOH, 12-16-2007 09:09:59
" but do these pump enough volume to check spray patterns too?"
Yes! Is it a military surplus? They work well for Detroit two stroke unit injectors. They may also test Detroit four stroke, though, I have only used them on the Detroit series 71, 53 and 92 engines.
LilFarmer
12-16-2007 09:40:38
Jeff,
I have sorta been looking around for a nozzle tester. Yes, they will pump enough volume for checking spray pattern.
I am in North Central Ohio.
E mail me with a price if you are interested in selling one or both.
PBuck_Excel@willard-oh Dot com
Replace the Dot with . and eliminate spaces before and after.
