Tool Talk Discussion Forum
TP Sandblast Cabinet Vacuum
David Maddux
12-14-2007 08:34:29
I am currently using a Vac-35 vacuum, I would like to upgrade to a 176DC unit. I am having a motor go out on the Vac-35. I have installed several motors in this unit and it seems like they last longer after I installed the hepi filter. They reccomend that if you are using it for more than 2 hrs. a day you need to upgrade. And I know I need to, it is hard to shell out 1,000.00 for a unit just for hobby restorations. I would be interested in buying a used one if someone is thinking about upgrading to the 301DC. Or if anyone has info on a different Manufacture that would do the same job for less money. Hope someone can offer some info here.
cwtech
12-14-2007 22:28:28
 Try a different motor? in reply to David Maddux, 12-14-2007 08:34:29
Looking at the TP Tools website, it appears your Vac-35 uses a type of vac motor commonly found in carwash vacuums.
There are two different types, which interchange as far as size, but their lifespans are quite different.
There are THRU-FLOW designs, where the "dirty" air passes thru the motor to cool the windings. .....The dirty air causes rapid deterioration of the brushes, bearings, bushings and commutator. (The picture at the TP website seems to indicate this type of motor is used on the Vac-35.)
The preferred type is a BYPASS design, where the dirty air is discharged around the periphery of the blower housing, and has a fan on the brush end of the motor to cool the windings with "clean" air.
To see what is available, check out the link below to a company which sells carwash supplies & equipment. ....They provide great service and have some of the lowest prices in the industry. ....I have been buying from them for over 30 years, and have never had a complaint.
Specifically, check out the GS Vac motor (item # VA30032) which sells for $31.50. This is a BYPASS type! .....We get wonderful life out of them in coin-op vacs which handle dust, dirt, and grit on a continuous basis.
(Incidentally, they are much less than the $79 replacement motor shown at TP's website.)
If you click on the item number of the various motors, you can see the specs.
Personally, I would try a different motor before I would resort to buying a high-priced collector.
.....The key to long motor life is to keep dirt out of it! ....Good filtration is a must!
Hope this helps!
If you need more info, my e-mail is: Lucenbruce(at)MSN.com
Charles (in GA)
12-14-2007 19:19:27
 Re: TP Sandblast Cabinet Vacuum in reply to David Maddux, 12-14-2007 08:34:29
Have had mine since summer, vac 35 I think, with the HEPA filter, no problems yet, I've used it quite a bit.
Charles
David Maddux
12-14-2007 13:40:57
Mine is not vented outside, it would be better if it was.
neblinc
12-14-2007 10:13:56
My 960TI is on the truck today, waiting for them to call me for delivery. Is your unit vented outside? I plan to do that with mine once I decide where to put it. I think it helps venting it to get rid of the fine dust.
Randy
