Tool Talk Discussion Forum
air compressor / painting
Ken Hageman
12-12-2007 16:12:57
Iam going to Paint a tractor, anybody have any recommdations on air compressor size and painting equipment type ?
El Toro
12-13-2007 03:36:19
 Re: air compressor / painting in reply to Ken Hageman, 12-12-2007 16:12:57
You should purchase an HVLP spray gun so you don't have so much overspray and they require a compressor that is capable of 10cfm's. If you're going to use hardener's you need a supplied air system. You don't want to breathe any of that spray. Hal
CalJim
12-12-2007 22:04:57
If you want a setup just for painting, forget the compressor and get a Turbine Sprayer. No lines to run, no water traps, etc. Just plug it in and paint. Less overspray too. Apollo Turbine Sprayer. CalJim
NTP
12-12-2007 17:43:39
A 1HP compressor with a 10 or 12 gallon tank is more than adaquate. You only need about 35psi to operate a decent spray gun and you will not be spraying 100% of the time. Any more pressure than that and you are throwing too much paint onto, and past the object you are spraying. I have both a 1HP and a 5HP compressor and have never used the 5HP for spraying. Do pressurize the tank and then open up the drain valve at the bottom of the tank to rid the tank of moisture, and also purchase a cheap inline air drier filter to attach to the air line just before the spray gun, and you will be good to go.
Ken Crisman
12-12-2007 17:10:34
5 hp 2 stage with cast iron cylinders & heads . God bless, Ken
