Tool Talk Discussion Forum
99 chev dash lights/fuel guage probs..
deanop
12-11-2007 03:55:22
I've got a 99 chev 1500 ls, that the dash lights don't come on until it warms up or hit a bump (sometimes)..Also, when I fill up my gas guage won't work, until I've driven about 50-100 miles than it works mostly..any ideas, or have you had the same problem..deanop
bhb
12-11-2007 06:50:35
 Re: 99 chev dash lights/fuel guage probs.. in reply to deanop, 12-11-2007 03:55:22
I received a notice that my 2004 GMC could have problems with the gauges. "The instrument panel gauge may stick, flutter or become inoperative. This may cause inaccurate readings, including the speedometer and the fuel gauge." If this happens they will repair it up to seven years or 70,000 miles. May be worth checking. Their number is 1-866-996-9463.
Bill
Joe (Wa)
12-11-2007 14:08:39
 Re: 99 chev dash lights/fuel guage probs.. in reply to bhb, 12-11-2007 06:50:35
Received the same letter about a month ago for 2003 Chev 2500HD. Entire instrument panel was renewed in that truck under warranty in 2005, no problems since.
Joe
circus
12-11-2007 04:40:40
 90% chance it's bad gd NText in reply to deanop, 12-11-2007 03:55:22
Stumpalump
12-11-2007 11:09:19
 Re: 90% chance it's bad gd NText in reply to circus, 12-11-2007 04:40:40
Yep those trucks are notorious for bad grounds. I added plenty all over mine to avoid problems on the advise of Chevy truck forums.
azharry
12-11-2007 04:22:38
I think you may have two different problems that are unrelated.
The dash lights could be a variety of things from a bad dimmer switch, to wiring, or a loose connection. Try adjusting the dimmer switch to a different position to see if they work better. I have also seen the connector for the headlight switch/dimmer melted.
The fuel gauge issue could be a worn out fuel sender, sulphur build up on the sender, or possibly but unlikely, the gauge itself. Good luck,
Mudcat-21
12-11-2007 07:33:49
 Re: 99 chev dash lights/fuel guage probs.. in reply to azharry, 12-11-2007 04:22:38
I have a 01 Silverado with the same fuel gauge issues. More then likely it's the fuel sending unit. Expensive part and involves dropping the tank to get at it. Mines been that way for over a year now. One of these days I'm going to change it out.
deanop
12-11-2007 09:41:29
 Re: 99 chev dash lights/fuel guage probs.. in reply to Mudcat-21, 12-11-2007 07:33:49
thanks guys,your input is greatly appreciated.deanop
