Tool Talk Discussion Forum
tractor lights
john c.
12-09-2007 15:45:06
Someone had a messagw a while back about putting a sealed beam unit in a 5 inch tractor light. I cant find it am wondering what the sealed beam # is
JoeK(WI)
12-09-2007 23:01:59
 Re: tractor lights in reply to john c., 12-09-2007 15:45:06
First,sealed beam units are coded by physical size,known as a PAR No.You would be needing probably a PAR36 bulb"size".Then there would be a 4 digit no which designates the lens design(spot,flood,fog,work pattern),voltage and candlepower of the element(s).Probably for a 12V tractor a 4411,or 6V a 4511..however there are dozens of PAR36 units to be had.
