Tool Talk Discussion Forum
Jumpstart question
`Bernie in MA
12-08-2007 15:05:15
I have a jumper box, 650 amps. It's about 3 years old. I used it to run a 300 watt 12V heater to thaw out my tractor power steering pump and it went dead after an hour. Is it time to buy a new one?
John T
12-08-2007 15:49:12
 Re: Jumpstart question in reply to `Bernie in MA, 12-08-2007 15:05:15
It probably just needs recharged n it will be fine. All those units are is a battery basically i.e. energy storage and the heavier more expensive units prob have more battery n store more energy then the el cheapos. What counts is how many amp hrs of energy they store which is the rating we used to see on batteries.
JT
Greg_Ky
12-08-2007 15:31:22
A 300 watt load @ 12 volts is a 25 amp. load. I doubt that your jumpack has a battery larger than a 20 amp. I would think that you are good to go with just a recharge.
Red Dave
12-08-2007 15:28:24
I don't think so. Those batteries aren't all that big, they are designed to deliver high amps for a very short time. You pulled 25 amps out of it for an hour before it went dead. It seems to me that it did pretty good.
