Welding pressure washer coil
tomp
07-19-2001 06:16:34
I am the lucky or unlucky owner depending on how you look at it of a hot water pressure washer with a split coil from freezing. I pulled the coil and found numerous splits. After MIG welding the splits i could see i then filled with water and found one last leak that is behind the outside run of tubes. Is there any way to repair this? thanks
bruce
07-21-2001 05:33:58
 Re: welding pressure washer coil in reply to tomp, 07-19-2001 06:16:34
Hi; Just wondreing what kind of hot pressure washer coil you were trying to fix. thanks
rhudson
07-19-2001 14:43:12
Hi tom, i'm amazed that you could weld it with a mig at all. i've done bunches with tig. i usually make sure its very dry, then purge the inside of the coil with argon to get rid of any oxygen. tape over the ends of the tube to try to trap argon inside. and like mark said pry, seperate and block open a space to weld.
Mark Kw
07-19-2001 13:10:05
Good luck! You're gonna need it.
Most times it's not worth screwing with these things because it ends up being nothing but a waste of time and money. I'd say if you got that much time into it alread, it's worth a shot ripping it down more to get at the leak and attempting a fix. As for how to get at it, that's something I can't comment on without seeing it. Sorry can't help you any more on this one other telling you to start prying and pulling to get it out where you can work at it.
