Tool Talk Discussion Forum
Dump truck L 8000 COMPARED TO L 900
lenray
12-07-2007 08:12:31
Have a 1977 Ford L 900
lOOKING AT A 1982 Ford L 8000
Both are 5 yd. Are they about the same size compared to what they can haul. Or is one bigger than the other.
The L900 HAS A 477 GASSER
tHE L8000 Has the Cat engine
Leland
12-08-2007 16:51:50
 Re: Dump truck L 8000 COMPARED TO L 900 in reply to lenray, 12-07-2007 08:12:31
the 8000 has a heavier frame ,it's basicly a light duty 9000 series .I can't remember all the details but go with the 8000 better built .
glennster
12-08-2007 04:19:43
if i remember, the L stands for lousiville, the hundred vs thusand denoted gas or diesel and the 8 or 9 designates gvw. my first diesel dump was an old ford with an 1150 cat, the early version of the 3208. they were a pretty good motor iff you took care of em. not the most powerful or neck snapping performance, but you are in a dump truck, not an indy car. she will get you from point a to point b. the governor on mine kicked in at 58 mph. that was it. critical thing with them old cats is NEVER rev them up when they are cold!!!! start em, and let them idle, they need to get warm and get good oil pressure before you work em, if you dont, you WILL scatter the motor!!
Marlowe
12-07-2007 13:15:36
parts are hard to come buy for that 477 and they get 4-6 mpg fair engine
lenray
12-07-2007 15:00:47
 Re: Dump truck L 8000 COMPARED TO L 900 in reply to Marlowe, 12-07-2007 13:15:36
tHAT 477 uses the gas. Ran great for the past 4-5 years. Now it has just started giving me trouble. Stall out going down the road--maybe stall at idle. Maybe run for 3 hours then act up--go another couple of hours and act up again. Can't depend on it.
Changed the inline gas filter and the big cannister gas filter under the hood.
Have great spark out of the coil.
Filters had a lot of small grit in them--very fine stuff.
Thinking I have a carb. problem. Will start up after much rolling over--then can restart a dozen times with just a hit of the key. Let it sit for a couple of hours and then can't restart.
It has an electric external fuel pump.
Any ideas out there????? ??
Larry806
12-07-2007 18:40:33
 Re: Dump truck L 8000 COMPARED TO L 900 in reply to lenray, 12-07-2007 15:00:47
Hey lenray I have a 67 850 Superduty with a 534 , it did the same thing yours is doing . I found the gas line was getting plugged where it comes out of the tank .
lenray
12-07-2007 19:11:35
 Re: Dump truck L 8000 COMPARED TO L 900 in reply to Larry806, 12-07-2007 18:40:33
Thanks Larry I am going to check all the lines out. Always enjoy your hard work and the sharing you do down there in Ohio.
You probably get a little less gas mileage than I do with that big ole Ford.
pair-a-dice farm
12-07-2007 10:04:45
I have a 82 L8000 10 wheel grain truck with a 3208 cat diesel. It is not turbo. Mine is very underpowered. I'm not familiar with the 477 Gas engine but would imagine it would be a gas hog. I get about 6-7 MPG with the cat. If L8000 you are looking at has a turbo that would be a big plus. The cat engine is basically a throw away, so take that into consideration. They are also getting pretty old. I had a valve seat come apart in mine and had to replace a piston and it was hard to find. I finally found one from an old dealer that was going out of business. Hope this helps
Rob in Indiana
12-07-2007 10:16:14
 Re: Dump truck L 8000 COMPARED TO L 900 in reply to pair-a-dice farm, 12-07-2007 10:04:45
Any part you need to repair a 3208 engine is still available from Cat as are reman engines.
JT
12-07-2007 09:55:47
Road district has an L8000 with the Ford 6 cylinder turbo diesel engine, will run 57 MPH
loaded, empty, up hill, down hill a little faster. lol
