Tool Talk Discussion Forum
Table saw blade speed
jack12345
12-06-2007 08:38:25
I'm replacing the motor on my table saw.I have a 3450 rpm motor that is geared to turn blade about 4000 rpm.The replacement motor is 1725 rpm and will have to buy a pulley .Whats the speed is best for a table saw? At 4000 rpm it seems to put a lot of fine dust in the air... would a slower speed reduce dust? Thanks, Jack
wdTom
12-10-2007 18:04:25
 Re: Table saw blade speed in reply to jack12345, 12-06-2007 08:38:25
Castiron pullys will out perform the whith metal pullys. They grip the belt better, and don't tend to come loos as much. I don't see any advantage to running faster than motor speed, (3450) more or less, and they seem to work fine at slower surface speeds. That is using a smaller blade with a slower surface speed. Especially if you are a little down on power running a smaller blade will help.
Leroy
12-10-2007 15:36:43
I have been watching this and the speeds mentioned seemed way too high so I just went out and checked my saws. 8" Craftsman 1725 RPM 1/2 HP on a 2 1/2" motor pully and 2" pully on the saw arber for a speed of 2,156 RPM and a 8" no name brand cheapy saw with a 1725 RPM 1/2 HP motor with a 2" pully and 1 3/4" saw arber pully for a speed of 1971 RPM and use a 7 1/4" blade on the cheapy 8" saw. Would not want faster and the 1/2 HP motors have all the power needed.
another doug
12-08-2007 04:18:15
I just found the problem with my auction purchased Craftsman 10" saw...loose pulley on blade arbor shaft , for years I couldn't find the problem, and last night my son and I were ripping some pine boards and she stalled the blade and we adjusted the belt, and it did it again, that also explains the rattle noise too, I will replace the pulley and make sure it stays tight, I always thought the motor was wired wrong,woot!
36 coupe
12-07-2007 03:47:37
Try a lower blade speed.Ive run an 8 inch table saw a lower speed for many years.Lower speeds take less power.A sharp blade is more important than blade rpm.
Pooh Bear
12-06-2007 19:15:32
Saw blades should turn at 10k to 10.5k feet/min
(RPM x (blade diameter) x 3.14)/12 = feet/min
Just under 10500 feet/min is real good.
I run 7 1/4 blades on my table saw
so there is less load on the motor.
I only switch to bigger blades when I need to.
Pooh Bear
Bud in WV
12-06-2007 16:44:05
We used to have to pull out the book to get info - and actully do MATH! I haven't tried this but it looks like it might help -
http://www.csgnetwork.com/pulleybeltcalc.html
kez
12-06-2007 14:44:33
Hi!
There are several variables to be considered. A few examples. The larger the diameter of the saw blade the slower the saw blade can turn. My 71/4� electric hand saw runs at 5500 rpm. My Makita 10�cutoff saw at 4000 rpm. A strong motor that doesn�t slow down when you push material into saw keeps up the blades rpm. The faster you feed the material into the blade the faster the blade needs to turn. As a rule finer teeth make finer dust. A larger coarse rip saw blade make good size sawdust. My guess is you have a 10� table saw and it would probably make you happy at about 4000 rpm. AK
