Tool Talk Discussion Forum
Kellogg Compressor
Pollack Pete
12-06-2007 03:57:17
I'm working an an old Kellogg-American model 331 air compressor.Does anybody know the oil capacity of this unit? No dipstick on the fill plug and the site-glass is too dirty to see anything.The last owner must have figured it needed to be filled to the top.Needless to say,I drained about a half gallon of oil out of the tank.It was waaaaa y over filled.Thanks for any info.
XRogerX
12-08-2007 16:35:22
 Re: Kellogg Compressor in reply to Pollack Pete, 12-06-2007 03:57:17
I'd try filling the crankcase with solvent to try and break up the scum inside the sight glass. Many of these can be pulled out and cleaned by passing some paper towel in through one of the holes in the backing plate and then swabbing the glass clean with an o-ring pick or the like. On some Kellogg's, the fill plug is near the base of the compressor, so you just fill to the top of the threads and you're good to go. If it's apart though, I'd try swabbing the glass clean.
