Tool Talk Discussion Forum
Front tires for a Ford 900
lenray
12-05-2007 13:28:55
Have a Ford 1977 dump truck with 10-20 tires with the tubes and the ring on them.
I am thinking of changing to the tubeless tires.
Was wondering if other models GMC IHC others on newer models have the tubeless tires and rims that would go on my 900 FORD.
Thanks
old
12-05-2007 14:36:38
 Re: Front tires for a Ford 900 in reply to lenray, 12-05-2007 13:28:55
What type of rims does it have?? Buds or daytons. Buds have lug nuts in the center area and daytons are more like a big donut. If its the donut type you will have to go to 22.5 rims but they will blot right on with not problem.
lenray
12-05-2007 15:09:21
 Re: Front tires for a Ford 900 in reply to old, 12-05-2007 14:36:38
HELLO OLD It is the type where there are 5 studs with nuts that are in a STAR type of formation with a machined piece of steel that is tightened down by the 5 bolt stud combination.
old
12-05-2007 15:52:25
 Re: Front tires for a Ford 900 in reply to lenray, 12-05-2007 15:09:21
Ok so your saying if your thin enough you can crawl through the rim when off the truck right?? If thats what your saying then there daytons. And if yes to what I said you will have to go with the 22.5 type rims/tires. Any good tire place should be able to get you used rims or new one. I've still have a few of them laying around from my truck driving days
