Tool Talk Discussion Forum
what type of welding?
tractorhank
12-05-2007 07:40:34
I have been into showing and restoring antique tractors for about 2 years now and I want to take a class on welding so I can do my own instead of sending it out. Continuing education here has 4 different classes. Which one should I take that would benefit me the most? Arc Welding, Mig Welding, Oxy-acetylene Welding, or Tig Welding. I have an older Arc welder that someone gave me that runs on 220 outlet and I also have a Mig welder that runs on 110 outlet. I have used the mig welder but my results at the time were not very good - no experience or teaching. Any advice would be appreciated. I plan on collecting tractors for a very long time. It is the most satisfying and fun hobby and the people you meet are fantastic.
trucker40
12-06-2007 15:31:23
 Re: what type of welding? in reply to tractorhank, 12-05-2007 07:40:34
I would take oxy-acetalene,then mig since you have a mig.Stick takes a lot of practice to do right.If you are going to work on a lot of tractors,over a long period of time,you wont need a stick much.You would need a 220 mig eventually.A lot of what you do fixing a tractor is weld tin,cast,or plate.None of it has to be X-rayed,or sonic tested.A good mig will handle that.You already have a stick,but its hard to weld thin stuff if you dont know what you are doing with a stick.If it was me,and I knew how to cut with a torch,I would take the stick course and the mig.Its good to know about a torch even if you dont have one.
You realize that if you take a course you arent going to be an expert when you get done,but its a lot better than nothing.
You need to learn about setting a mig if you didnt do very well when you tried it yourself.Thats whats the hardest,and thats not all that hard.If you are a mechanic,its easier to keep a mig going than some stuff.Its easier to weld in different positions with a mig for me,its a cleaner weld,which you need if you arent a good welder,and its a good,strong weld if you do it right.
You can buy rods for the stick that will almost weld themselves if you can get to it flat,trouble is you dont always have a choice.Its going to take a while for you to learn how to weld an uphill,full penetration weld,especially if you dont have a pipeliner.Its a little hard to do with a buzzbox,but its possible.
What you need is a good grinder if you cant weld very good.If it doesnt look good,grind it off and try again,especially if you are using a stick because if you have a weld thats full of slag its no good.Its possible to make a bad weld with a mig,but its not going to be because of slag cause there is only a little slag on a mig weld.So somwhere in there you need a grinding course too.
dr. sportster
12-06-2007 13:53:48
If you take Oxy/Acet and arc welding and learn it you will be able to mig and tig by just using the machine.Tig is gas welding skill using an arc and if you can run rod youll figure out the mig also.Join night school and use their electricity to learn.Its an endlessly useful skill.So Id say Oxy acet then arc if its separate classes.Good luck.
135 Fan
12-06-2007 11:44:03
Just for information purposes, I'll try to explain welding processes a little. First of all, for 99% of the welding done by people on this board, having the absolute strongest weld won't be necessary. For really critical jobs, TIG welding is by far the best. It's also takes longer to master and is slower. Stick welding is stronger than MIG or Flux-core. I'm not saying Flux-core isn't strong. It is but not as strong as stick. It is a high production process. Most pressure vessel codes don't allow Flux-core. It is widely used for structural steel because it is fast. MIG is used a lot for root passes on pressure vessels and piping, followed by stick fill and cap. I've worked on 2 1/2 inch thick material beveled out for a 18 inch nozzle and it all had to be done with stick (7018). After the bevel was filled up we had to put another 2 1/2 inch thick repad around it that was beveled for 100% penetration. I was working with another welder on night shift and the day shift had 2 welders on it. It took a long, long time to complete. Especially because the guy that cut the repad made it for a 20 inch nozzle. The entire job was done with stick and had to pass ultra sound inspection. Flux-core would have been way faster but wasn't allowed because it is not as strong. MIG is a strong weld when done right but is also more common for problems like cold lap or lack of fusion. Stick has always been considered the least prone to problems. Hope this clarifies things a little. Dave
Stan in Oly, WA
12-06-2007 15:07:07
 Re: what type of welding? in reply to 135 Fan, 12-06-2007 11:44:03
Hi Dave,
I have the feeling we've been over this before but I couldn't find it in the archives, so I'm going to bring it up. Why is stick welding stronger than wire feed (MIG, F/C, or dual shield)? It doesn't seem like it could be because of the quality of the steel of the electrodes. If you were using the best ER70S-6 available, with 100% CO2, what would be inferior about that compared to your favorite brand (Air Liquide, isn't it?) of 7018? I realize that wire feed is subject to cold lap and lack of fusion, but aren't these largely due to operator error? Couldn't you, personally, weld two pieces of bevelled 1" plate together using the setup I described above (or some other electrode if you know of a stronger one---but still in the 70KPSI class) and turn out a weld that was just as strong as if it had been done with 7018? If not, why not? For it to not be as strong seems to defy the basic premise of welding: that if each pass achieves complete fusion with the parent metal or the previous pass, the end result will be the equivalent of a single, unwelded unit (give or take the effects of the HAZ---but it was my understanding that stick is more likely to cause a problematic HAZ than wire feed.)
The code requirement that stick be used rather than MIG or F/C in certain circumstances suggests that stick is stronger, but doesn't prove it. Even if identical results were possible with different processes under ideal conditions, the code could address the real world situation that one process is more likely to result in an unacceptable level of defects.
In short, using equivalent electrodes is stick inherently stronger than wire feed, or is it that the common defects of wire feed just make it turn out that way.
All the best, Stan
sl in ww
12-23-2007 19:02:44
 Re: what type of welding? in reply to Stan in Oly, WA, 12-06-2007 15:07:07
ww
135 Fan
12-06-2007 17:56:14
Stan, I wish had my books from school. I loaned them out years ago and never got them back. They had a lot of info. When I referred to stronger, it was in the most critical applications. MIG and flux-core at high amps are very fast and the steel cools faster than with stick. Especially for multiple pass welds stick is stronger because you use more passes which gives a finer grain structure. Actually smaller rods for the same overall size of weld are stronger for the same reason. The only thing is that on thick pieces too small of rods don't put enough heat into the steel and are slow. Some procedures specify the size of rod, preheat and inter pass temperature. Most of the MIG roots I did were with an ER80-S2 wire. A lot of critical welds are stress relieved and the post stress relieve properties have to taken into account. There's a bunch of factors to consider in determining what is stronger. For general welding it doesn't make as much difference what process you use as long as it's done right. The argument that they all melt the steel isn't valid. In school we experimented with welding up "V grooved" 100% penetration test plates. With 7018 you could dunk them in water right after welding and they would still bend in the press without any cracks. Try that with 6010, 6013, or 7014. If they all melt the steel so therefore all have the same result, why are there different rods? Welding is a very complex technology and is also one of the most important innovations ever developed. No one person could ever come close to knowing all there is to know about it. Dave
Stan in Oly, WA
12-06-2007 23:01:55
 Re: what type of welding? in reply to 135 Fan, 12-06-2007 17:56:14
Hi Dave,
"If they all melt the steel so therefore all have the same result, why are there different rods?"
It's my understanding that the differences between various stick electrodes within a given tensile strength classification have more to do with the composition of the flux coating than differences in the composition of the steel. Different manufacturers might use steels of their own special formulation, but I've never read promotional literature by any manufacturer
stating that the steel in their 70xx rods is better than the steel in their 70yy rods. I understand that this is circumstantial evidence, but it's something to be considered.
7014 rods and 7018 rods could be made from the same batch of steel and that wouldn't prevent the 7018 from producing stronger welds than the 7014. Why? Low hydrogen. Low hydrogen is a characteristic obtained from the flux and through the required handling of the 7018.
Why are there different electrodes? Different needs. A person might prefer to use 7018 for every stick welding task but not have a rod oven to hold the rods at the required 250-300 degrees F., not have enough money to open a new package of 7018 for every job (to get around the need for a rod oven), or might have an AC only welder which absolutely won't keep 7018 lit at any amperage the owner can control. But, as you point out, not every welding job is a bridge in Minneapolis, or a heavy duty trailer to haul nuclear warheads. If 7018's characteristics aren't essential to the job, or required, the person might use 7014 because it's AC friendly, or 6013 because it restrikes so well, or 6010 or 6011 because the workpiece is dirty and/or the fitup is poor. That, in my opinion, is why there are different rods.
All the best, Stan
135 Fan
12-06-2007 23:41:54
 Re: what type of welding? in reply to Stan in Oly, WA, 12-06-2007 23:01:55
I agree with you Stan. Different rods have different purposes and are better for certain jobs than others. I was only referring to another post that said they all melt the steel. Bare electrodes melt the steel too, but who would want to use them when there is a better choice? The flux on the rods contains alloying elements and other additives that can greatly alter the physical properties of the weld. A 7014 for example has a heavy flux that contains a majority of iron powder for faster deposition. A 7018 might have a slightly higher grade of steel for the bare wire. In higher strength rods the base steel is higher grade. Flux can only do so much. In sub-arc welding different fluxs can be used with the same wire for different results or weld properties. Stick is kind of the same. In Flux-core there are lots of variables. Some wires are good for multi-pass welds and some are recommended for single pass only. There's some pretty smart people developing welding consumables and testing them. I've used some Innershield Lincoln wire that required something like 17 passes on 3/4 inch thick V butt welds. It was just a general purpose wire but 17 passes wouldn't save any time over stick. Dave
Stan in Oly, WA
12-07-2007 22:22:38
 Re: what type of welding? in reply to 135 Fan, 12-06-2007 23:41:54
Hi Dave,
Well, you're right, I'm wrong. I e-mailed Lincoln Electric and got a response within a few hours: "They are a combination of both steel and flux. Certain steels go into certain electrodes as well as the flux." Not only were you right but you write more clearly than that, too.
Keep up the good work, Stan
135 Fan
12-07-2007 23:03:21
 Re: what type of welding? in reply to Stan in Oly, WA, 12-07-2007 22:22:38
Hi Stan, I don't think it's a matter of right or wrong. A lot of people would say it's a bad idea to use a coat hanger in a pinch for gas welding. While it might not be as strong as an actual welding rod, it is still a good steel as it has to be able to twist without breaking. Some coat hangers aren't so good. A lot of factors have to be taken into account concerning what rod to use. Elongation and charpy vee notch impact values are a couple of the most common specs. given for rods in addition to tensile strength. 7018 for example has to meet a minimum of 20Ft/lbs impact strength at -20 deg.F. Some higher strength rods will meet the requirement at -50 Deg.F. I have heard of drilling rigs coming up here from the warmer south that failed in the colder climate. I picked up a dragline brochure and one of the options listed is cold weather steel. It all depends on the specific job but it's always better to error on the stronger side than the weaker. Except possibly for something like a bridge that has flex designed into it. On a specific application like a bridge, over welding could make it too ridgid and cause a failure. I'm glad I don't have to design these things. There's a lot to know. Dave
Puddles
12-08-2007 05:25:10
 Re: what type of welding? in reply to 135 Fan, 12-07-2007 23:03:21
Hi Dave, don�t know how long you�ve been in the welding business, you obviously know the trade! I remember after the 1995 Northridge earthquake how structural welding in some ways went back to the drawing board. Especially in seismic applications. Once FEMA got involved they really up the annie from AWS specs! The FEMA 353 spec is very strident, and costly! Couple of examples, if welding stops for more than 8hrs, the wire must be removed from the machine and stored in an electrode oven. Wire cannot be outside its packaging (not counting time in rod oven of course) for more than 24 hours. Here is an area where I think the manufactures have a lot of catching up to do, I can only think of a hand full of self shielding wires that even have Charpy notch ratings! Even less that meet FEMA 353.
Almost immediately after the earthquake our in house engineers started insisting we use NR-232 for all bridge falsework. At this time the majority of the welding machines in our equipment rental feet were CC, we had to go outside to rent CV machines. Here again trying to change grown men�s thinking process! The average weldor in the field why he can�t run NR-211 anymore to the purchasing agent why he can�t buy the cheaper CC machines. Like I said, an ever changing business!
Puddles
12-06-2007 13:05:25
For your reading pleasure, and education ;<) Link
135 Fan
12-06-2007 18:39:03
 Re: what type of welding? in reply to Puddles, 12-06-2007 13:05:25
This is a highly specific and critical job. The Flux-core wire used met the requirements and was used because it is much faster. However the article points out that 5000 lbs. of stick electrodes were used and also the root and hot pass were done with stick. XX10 variety because of its post weld properties. My former neighbor worked on the Alliance pipeline. It was over $1,000,000,000 and was done with MIG. He was qualified for the hot pass but also had to have his stick qualification. He was amazed that they would pick up the pipe with only a root pass, that was done from the inside with automatic equipment. I think he said the internal root pass machine had 6 mig guns on it. Again on this job, stick was always a qualified procedure. On some really critical jobs MIG or Flux-core aren't qualified. For this pipeline Flux-core was. I've seen 10 ft. diameter vessels that had to have TIG root passes. That takes a while to do but is necessary to meet the requirements of the weld. I really doubt anyone on here will be doing anything that critical. I'll stick with my opinion of stick being stronger (maybe not by much) than Flux-core. The pipeline could be done with all stick but the same can't be said for the Flux-core. Also the equipment needed to do high quality stick welding is way cheaper and less troublesome than for any wire feed welding. That was an interesting article. I saw a picture in a Lincoln book of doing pipelines with a portable Submerged arc welding process. Sub-arc has been around since the 20's and is very fast and strong. One of the first applications was welding beer kegs. Aren't you glad someone invented arc welding? Dave
Puddles
12-07-2007 06:06:16
 Re: what type of welding? in reply to 135 Fan, 12-06-2007 18:39:03
Hi Dave, when I read that article I was a bit surprised in one paragraph where they stated the root pass was done with .035 wire. I remember one time running the night shift on a project welding 10-foot diameter 1-inch wall pipe for the US Army Corp of Engineers. 100 % X-ray. I wrote the welding procedure for this project. We used 1/16-dual shield with 100% CO2. The owner of my company hired a �welding consultant� for the day shift. The Corp required that the first passes be air / carbon arced out from the backside. Luck have it the day shift got to start the welding first. Note this pipe was in the 2-G position. This welding consultant had the day shift start on the inside first. I would have never done that. Reason being we were in a new area with weldors we didn�t know, why put them where you can�t watch them, and they have to work on a platform suspended in the air 100 + feet. Anyway this ended up a disaster! These 10-foot dia pipes were nothing but a chimney! The outside air was coming through the gap at mock-6, which blew the gas coverage away. We ended up buying ceramic backing tape to block the wind so the crews could get the root pass in. We ate up the entire welding budget on this first joint. Between welding it, and selling the x-ray.
I�m personally not a big fan of mig / wire feed welding but it has it�s place, and with the cost of labor, don�t fool yourself it�s here to stay. I�m super surprised that on this pipe line project management ever convinced those �old school� pipeliners to use wire feed at all. As a manager myself one of the hardest things I did was convince people to work out of their comfort zone! Getting grown men to change their thinking process is an uphill battle at best!
In my opinion making the statement stick is stronger than wire is a bold statement, and to a degree uninformed, but we are all entitled to our opinions! RIGHT! If you do your research there is a wire on the market that is comparable to just about any stick. One way to look at dual shield, is you have the best of both worlds! Flux, and gas coverage all in the same process. Far as not running wire in a critical situation. That gets down to who wrote the welding procedure, and what engineer approves it. I�ve written hundred of welding procedures, had to make changes to a lot of them, at the request of the engineer of record. It gets down to what information you put in front of the engineer of record, and why. Welding is a huge business, and an ever-changing business. Remember the old saying �there is more than one way to skin a cat�? Same goes with welding ;<)
135 Fan
12-07-2007 11:48:32
 Re: what type of welding? in reply to Puddles, 12-07-2007 06:06:16
When I say stick is stronger, it may only be by the very slightest margin. On a job that is back gouged for 100% penetration, you don't have to worry about getting an x-ray quality root pass since it will be gouged out anyway. Jobs that are back gouged take way longer. MIG is very common for root passes at low currents in short circuiting metal transfer. Most big pipelines are done with automatic MIG set ups for the entire weld. On that job, a specialty pipe was used which dictated what procedures could be used. Flux-core met the requirement for the fill and cap only. Stick met the requirement for the entire joint. Almost all steel weldments can be done with a stick procedure qualification. On a lot of them other procedures will also be qualified. The same can't be said for Flux-core. When you look at specialty steels, most of them can only be done with TIG or stick. It may be because it is easier to get the right composition in a stick electrode. You don't see stainless Flux-core. Stainless is done with MIG sometimes but for the most part it's done with TIG and stick. Real critical work is done all with TIG. TIG is the strongest weld when done properly. That doesn't mean other processes aren't strong. On work that has to meet really exacting requirements, stick is specified over Flux-core, even though Flux-core would be faster. It doesn't have anything to do with operator preference. It has to do with the physical properties of the welded joint after it is completed. For all intense purposes, unless someone on here is building a nuclear reactor, it won't make any difference which process is used as long as the correct filler metal and preperation is done. Flux-core is getting close to stick but isn't quite there yet. Welding technology has taken huge leaps forward in the last 15 years or so. Who knows what they'll come up with next. Dave
Chuck UR
12-06-2007 05:30:46
250 class Mig / 220V.
Weld 20g to 1/2"
Don't believe anyone that tells you one is stronger than another - they all melt metal.
Some easier than others and some prettier than others.
Puddles
12-06-2007 06:49:55
 Re: what type of welding? in reply to Chuck UR, 12-06-2007 05:30:46
Two big mistakes made with a Mig welder by the novice, beginner, amateur, dabbler, greenhorn. A true professional weldor will know this!
Not running hot enough! Not really knowing how to set a machine! Not knowing when to switch from 75 / 25 to 100% CO2!
Now spray arc, is another story ;<)
36 coupe
12-06-2007 04:02:50
I started with a stick welder my Dad bought for 10.00 in a scrap yard.This was in the mid 50s.I still use this welder.I worked on a farm afternoons that had a Lincoln 225 stick welder.My 10.00 welder was 150 amp and didnt handle 7018 rod so I bought a new Lincoln 225 for 93.00.This was in 1963.Ive oiled the fan motor but no other repairs have been needed.I borrowed an old airco welder that did ac/ dc stick welding plug mig to do some body work on my pickup.Mig welding is NOT easier to learn than stick welding.After I returned the Airco I bought a used Miller 130 Mig welder.This is a nice welder for work within its range but the gas expense and chasing after gas is something I dont like.Flux core wire is expensive and the residue will attack your paint work.The big mig welders use high priced circuit boards.Fellow I know needed a new board for an Esab machine,700.00.Mig welders have a lot of parts that will need replacing so cheap mig welders are NG.You will need parts backup.
bigslickone
12-05-2007 18:04:56
I have been a mig welder for over 8 years. I weld everything from 1/16" thick to 1" thick. I have messed around with a stick welder but I am no where proficient with it. Welding with wire is not as ridgid or strong as stick. If you are looking for appearance then I would go with Mig.
Puddles
12-05-2007 18:18:02
 Re: what type of welding? in reply to bigslickone, 12-05-2007 18:04:56
�Welding with wire is not as ridgid or strong as stick�
Now you didn�t really mean that did you?;<)
Ever hear of dual shield, with 100% co2?
Bobby/Tx
12-05-2007 17:16:42
Hank, I"m no profesional weldor by any means. An arc welder would be a lot better for metal 1/4" & thicker. It"s a little harder to master though. At least for me, my arc welds sometimes look like a drunk mud dobber nest. I have a little Hobart 140 that i wouldn"t take for though. It"s great for sheet metal up to about 3/16". Hope this helps & good luck.
soundguy
12-05-2007 16:58:39
I self taught myself stick and then mig... I personally like mig for thin materials, and stick for thick materials.
so far.. I've "needed" mig welding -0- times to fix my tractor .. but have "needed" stick welding multiple times to fix my tractor.
IE.. if i have to glue 2 3/4" otr 1" plates (back) together... I can either do it with a 250$ 235A stick welder.. or a 2500$ 250a mig... Guess which one is in my garage... the stick!
Soundguy
J.C.in AZ.
12-05-2007 14:48:07
Electrode[stick] MIG-TIG-etc are all a form of ARC Welding. Arc Welding is a generic term now a days so I would advise to learn Stick Welding and practice-practice until you are proficent at that and also practice Acy/Oxy Welding until you can weld 20 Ga. cold rolled sheet with both Electrode Arc and Acy/Oxy with out blowing holes and then you can advance to Mig and Tig if desired.Mig and Tig require special equipment and a supply of Gases so both are relativly expensive options but not out of reach for most Mechanics.Some AC Welders and DC Welders are Student Friendly and some are not. I think a Forney 220 Volt Buzz Box is a good starter for a Novice. My Forney has helped me out a lot of times over the last 40 years and my Lincoln 120 Flux Core Wire Feed Welder has made me see that welding is on a forward march in technology and Mfg's. are trying to make the Craft attractive to any one who wants to learn.
135 Fan
12-05-2007 11:03:35
I suggested arc on your other post but it might help to know how long the course lasts or how many hours it is. Maybe you can take more than one course and get a discount? Oxy/acetylene will teach you what to look for but if you haven't done a lot of arc welding, it is quite a bit different. You want the same in the result but having to do it with a welding helmet and dark lens takes some practice. Dave
Stan in Oly, WA
12-05-2007 10:02:07
Hi Hank,
Vocational school and community college welding programs are often set up so that all types of welding are taught in the same shop at the same time. You might be able to determine if this is the case by looking at the catalog/class schedule. Here, for instance, you would see that half a dozen or more individual courses are offered but that they meet at the same time, in the same place. The instructor has more than enough time to help each student on whatever process he or she is learning.
Unless your local school has way more money than most, they're just not going to have separate facilities for different kinds of welding, so you'll get to at least see, and very likely try, every process during a single quarter, anyway.
In any case, start with oxy/acetylene welding. In my experience, people who don't start with O/A usually won't understand the underlying process of metal fusion as well as those who do, and are often worse operators for it. Besides, no farm or shop can really afford to be without an oxy/fuel setup, mainly for cutting, but also for heating and brazing. (I left out welding because you can't really weld with any fuel except acetylene, and O/A welding may very well not be your eventual process of choice for a number of reasons.)
Proceed, by all means. I firmly believe that learning welding at a public school is one of the last of the really great bargains.
All the best, Stan
guido
12-05-2007 10:54:33
 Re: what type of welding? in reply to Stan in Oly, WA, 12-05-2007 10:02:07
Hey Stan
It is a bargan to go to the public schools for classes. I have done it for welding 2years after work at night $5 each year. It has made me a better welder than I ever was. No xray quality mind you, But good enough to get by.
Guido.
Stan in Oly, WA
12-05-2007 13:10:18
 Re: what type of welding? in reply to guido, 12-05-2007 10:54:33
Hi Guido,
$5 a year? It's not THAT much of a bargain for most people. From what you said in a previous post, I thought you were a welding instructor. If you aren't you must teach something else and get a rate that amounts to free for classes you want to take at the school. My wife, the professor, can take classes free at either the local community college or college but she never has the time. I don't pay because I'm sometimes an assistant in the welding program, and usually an assistant in the metal arts program. But when I described public school/college welding programs as a great bargain, I meant at full price---around $125-150 per quarter here.
All the best, Stan
guido
12-16-2007 13:46:54
 Re: what type of welding? in reply to Stan in Oly, WA, 12-05-2007 13:10:18
Hey Stan.
On my last post a meant to send you the link of the tech. school I had told you about.
Here it is: penncotech.com.
Let me know what do you think obout the site.
Guido.
guido
12-13-2007 15:06:50
Hey Stan
The $5 was all I paid as a resident for 1 year of class. Took 2 for welding back in the 70'S.
A took also 2 years of refrigeration and air conditioning, all at night after work. As I look back it was worth it. I retired from the local Private Tech. school with automotive ,diesel and marine courses and some computer technology was
in the curriculum as well.I was head instuctor when I retired.
Guido.
DouginMI
12-05-2007 09:40:42
Depends on what you plan on welding.
I would suggest you start with a MIG class for sheet metal repair and other steel parts. If you plan on welding cast iron or heaver than 1/4" to 3/8" steel I would suggest a stick class. For aluminum or SS I would suggest a TIG class. If you plan on welding steel thicker that 3/16" I would suggest your stick welder or a MIG that is 220V input. Take a look at this site lots of welding stuff>Link
Doug
