Tool Talk Discussion Forum
T-Bone or others, LP joint compound
Rick Kr
12-04-2007 22:04:18
I put in a line for my LP today and I used regular pipe joint compound Oatey #31228. The grey stuff. On their website the only thing it says to not use it on is on Oxygen lines.
Is this OK for LP? or do I have to tear it apart and redo with joint compound that specifically says OK for LP?
Thanks,
Rick
Bud in WV
12-05-2007 13:44:15
 Re: T-Bone or others, LP joint compound in reply to Rick Kr, 12-04-2007 22:04:18
Rector Seal #5 is all I use on propane, oil, gasoline or air fittings. It' works.
Note - I also learned the hard way that you do NOT use Rector Seal in a water line. It seals fine but you still taste the stuff in the water 2 years later!
Rick Kr
12-05-2007 08:26:07
Thanks for the answers.
I checked with my propane supplier, and they said standard pipe dope is fine.
I just wanted to be sure. Can't be too safe with gas.
Thanks all.
Rick
El Toro
12-05-2007 10:31:48
 Re: T-Bone or others, LP joint compound in reply to Rick Kr, 12-05-2007 08:26:07
You can easily check for leaks with some warm soapy water. Just brush some on each joint and look for any bubbles in the soap. Hal
Chris(WA)
12-05-2007 07:24:04
They say not for Oxygen Use because the pipe dope contains oil. Oil and Oxygen don't mix well, Fire Hazzard. It should be fine to use with a fuel gas such as propane.
rgvtx
12-05-2007 05:03:35
If it says it's OK, then it probably is but..... .
Like Arkandan said, use Rectorseal #5. It's a bit messy to use and expensive compared to the others but IMO it is and has always been the best on the market.
As for teflon tape, I would never use that for a gas line. There is a special teflon tape for gas that is normally yellow in color, but I still won't use it. While threading the tape will cut and just one little piece that ends up inside of the line (it can and will happen) will stop up a jet at your appliances. That's not a fire hazard, but it sure can be frustrating when you can't get your stove to light one day.
El Toro
12-05-2007 04:01:18
I use Gasoila "soft set" for any of the gases and water. Most plumbing stores carry this. Hal
www.gasoilacom
Arkandan
12-05-2007 02:27:11
I just went through a LP piping ordeal a week or so back. Used 1" and �" black pipe mainly. Had to provision for a LP fireplace, LP furnace, LP water heater, LP range, and a auxiliary LP heater in the basement. Used the Oatey white stuff that said right on the bottle suitable for LP. Got done and did the pressure test and had leaks in several locations. Didn't incorporate unions as often as I should have so it was a beast to deal with. Finally tore it completey apart and cut in unions and used teflon tape in conjunction with RectorSeal pipe sealant at all joints. This was recommended to me by the furnace guy who worked with gas hook ups also. When I got done the second time I had not one leak and we put pressure on for three days to test. Got that RectorSeal at Lowes. It's a yellow compound and worked well for me. Hope this is my last dealing with black pipe or any other threaded pipe. Good luck and think SAFE.
