Tool Talk Discussion Forum
HOBART WELDER
oliver-2150
12-01-2007 11:17:51
i was wondering if the hobarts are made buy miller? i thought they were but i am not sure. whether they are or not does any one have any experience with hobart welders? i was looking at the ironman 250. is it any good? thanks
oliver-2150
12-04-2007 16:28:21
 Re: HOBART WELDER in reply to oliver-2150, 12-01-2007 11:17:51
thanks guys for all the input.
shannon from ohio
12-02-2007 06:17:00
Own a MAC Mw 115 mig welder. Made by miller,hobart,etc.Decent welder though..... ...
36 coupe
12-02-2007 02:07:47
Miller and Hobart are owned by Illinois Tool Works.Not many Independant companies left.
Roy Suomi
12-01-2007 19:26:39
I own Snap-On mig welder , but at work , there's an Ironman 250 with a Miller gun..Have not had any problems with the Ironman in 5 years of use..I don't weld everyday , but I probably have run 10-12 10 lb. spools of wire through it..figure on some consumables , tips , nozzles should be kept in stock..I usually run .035 wire for all around welding..Recently ran 308L stainless when mounting stainless salt spreaders on the new plow trucks..Had to use a helium,argon,co2 mix for stainless... For normal steel welding I use 75-25 argon,co2 mix..
S.Crum
12-01-2007 17:26:59
Check this out.
http://hobartwelders.com/weldtalk/
RobMD
12-01-2007 15:22:10
the ironman series welders are the exact same things as the miller welders. Hobarts are cheaper, therefore, i bought a hobart.
Horseturd
12-01-2007 14:42:36
Hobart was its own company for many years, but now both Hobart & Miller are owned by Illinois Tool Works (ITW). I own a Hobart Champion Portable and can not complain about anything on it.
Bobby/Tx
12-01-2007 11:26:55
Hobart and Miller are owned by the same co. You can read alot about the IM 250 on hobart"s website. Search webtalk.
