Tool Talk Discussion Forum
building fence in the winter
ric1
11-30-2007 17:47:32
im going to build a 5 or 6 strand life time fence (high tinsel)should i wait till spring or could i do it this winter im in ohio ill be driving the post some are locust and some will be pressure treated post. thanks
RobMD
11-30-2007 18:25:02
 Re: building fence in the winter in reply to ric1, 11-30-2007 17:47:32
When the ground is frozen in the winter, GOOD LUCK trying to get a post in.
ric1
12-01-2007 04:03:28
 Re: building fence in the winter in reply to RobMD, 11-30-2007 18:25:02
the winters here in southeastern ohio arent all that bad around here the ground is more soggy and wet than frozen most of the time. the only thing i was really concerned about is the post moving a little when the ground does freeze some.i see the contractor/fence builders doing it all winter so i assume it can be done witout having any problems
T_Bone
11-30-2007 18:04:26
Hi ric,
What you might consider using is 1/8" 7x7 galvanized air craft cable. Large diameter so easy to see, more stretching strength (1700psi) and cheap, about $37/1000ft delivered. Drawback is you have to order over a $1000 worth at a time to get free shipping.
T_Bone
