Tool Talk Discussion Forum
power warsher
jhill
11-29-2007 10:25:40
on the gasoline powered warshers when you are finished do you just blow out the water with compressed air or do you flush out with some kind of antifreze?
john *.?-!.* cub owner
11-29-2007 18:53:11
 Re: power warsher in reply to PJH, 11-29-2007 10:25:40
I hook a hose wiht a funnel on the inlet side of mine and pour some rv antifreeze in it. then pull rope till pink comes out pressure fitting.
NTP
11-29-2007 14:07:24
 Re: power warsher in reply to jhill, 11-29-2007 10:25:40
Blow it out with compressed air. I made a short hose with a quick disconnect for my air compressor which makes it a quick set-up in the fall. I have never had a problem with the pressure washers in the spring.
RobMD
11-29-2007 10:58:08
i don't do anything like that. I just pour antifreeze in the pump when sitting for longer than a month. Helps keep the seals from drying out.
