I have built a similar device. I used a fuel oil tank as a furnace (outside), and put in a 100 lb propane tank as the boiler. The propane tank was plumbed to a hot water pump, and then to cast iron radiators, and heat exchangers. The wood fueled fire kept the water in the boiler hot, and the plumbing transferred the heat to the shop. It worked well, with the exception of the cast iron can only dissipate certain amount of heat under a non steam situation. I added the heat exchangers later, and they made a big difference in transferring heat. My goal was to avoid a pressurized system, but that did not work well. We ended up putting steam vents, auto fill and blow off valves to keep the system at a constant pressure. In reality, steam has more energy than hot water, but is more dangerous. Steam heat of vaporization has 2260 kJ/kg as opposed to hot water which has 418 kJ/kg, so once you get past boiling, the available energy becomes quite large. Anyway, your system will help defer the fuel oil energy used to heat the shop, but it depends on the efficiency of the water heating device, and the available BTU�s in a unit of fuel source. If you need a cost of energy comparison, look online at the department of Energy, they (unbiasly) compare the cost of heating sources. Right now, in our part of the world, resistance heating costs about as much as propane/natural gas. If you want to reduce your energy usage, additional insulation is a good investment. Depending on your area, a heat pump, or geothermal may be the way to go. I plan to use my furnace (with slight modification) until it is non functional, then I will look into some type of geothermal unit (possibly just burying plastic pipe, and pumping the water to a heat exchanger in the shop) to keep the shop at 50 to 55 deg when not in use. I would do like you said, and turn up the heat from a secondary furnace when I need to use the area. I only say this because I have access to the equipment and property to make this work. Hope that helps Tim
