The Porter Cable 6", #7336, is a bear for work. In the early 80's they outclassed all other ROS around the boatyard where we worked on our old cruisers. The others sat on the bench and we took turns using the Porter Cables. Then in the late '90's PC started using bushings instead of roller bearings and the life expectancy of the machines went south. The latest one I bought has ball bearings again, and works very well, hopefully for a long time. If you are buying used, get one from the eighties or a very recent model. As far as dust pickup, forget it. This thing produces far too much dust to handle with a vacuum. Get a comparable Dewalt (3 amps, rather than 5.6) if you want to go the vacuum route. I wore one of them out, too. Not a bad machine, but no Porter Cable 7336. One other item: hook and loop systems cost the earth to use in comparison to the old-style stick-on disks. Princess Auto has the stick-ons on sale from time to time for about thirty five cents per sheet. If you are buying online, you'll have to look very carefully at the ad to get the stick-on pad rather than the velcro model. $150. should buy it from Porter-Cable.com.
