Tool Talk Discussion Forum
T_Bone wsmm66, bare wire welding follow-up
Stan in Oly, WA
11-25-2007 21:38:17
This afternoon I finally got a chance to try some bare wire welding to see for myself what it's like. I used a bare 1/8" O/A filler rod, set my stick welder at 140 amps DC+ and tried to weld a piece of 3/4" rebar along the edge of a 10" long scrap of 3/4" plate. My findings:
1. Very easy to stick rod.
2. Very hard to hold arc.
3. Very hard to remember that any part of the rod will arc.
4. Welds were not pretty.
The scrap of plate I used was the horizontal member of 2 pieces in a T-joint configuration. I kept bumping the rod against the vertical piece, causing it to arc, and startle me, each time. It was very difficult to strike an arc without having the rod stick, but not as hard as it was to hold an arc. I never managed to weld more than about 1/2" before I would lose the arc. I felt that it could be done with some practice, though. The welds were bad looking in a different way than I expected---they looked more like the result of poor welding technique than weld contamination. From reading about the history of arc welding I know that the process didn't really gain acceptance until coated rods were developed because the quality of bare rod welds was unreliable. From trying it for all of five minutes, I got the impression that decent looking welds could be achieved with practice, which would make it that much harder to predict that they would be likely to fail in use.
Stan
BobOHIO
11-26-2007 19:29:47
 Re: T_Bone wsmm66, bare wire welding follow-up in reply to Stan in Oly, WA, 11-25-2007 21:38:17
An elderly friend of mine said he went to welding school during WWII when supplies were in demand. Students used bare wire to practice and said when the teacher finally broke out the rods with flux it flowed like butter. He was a great weldor.
JDB
11-26-2007 13:43:31
In welding school they made us spend so many hours using bare rod to learn arc control. It was frustrating but a good learning tool
Bus Driver
11-26-2007 04:37:12
I suspect that the MIG welder has a different electrical output from the conventional stick welder. The MIG probably has high frequency output. Your results are actually better than I would have predicted, so you must have some talent as a weldor. On my gas-shielded MIG, simply forgetting to turn on the gas results in bare-wire-only. Not good at all. I have never welded MIG with flux core. I just use the Lincoln Idealarc AC/DC 250. Mine was made in 1957, fine machine.
135 Fan
11-26-2007 11:20:48
 Re: T_Bone wsmm66, bare wire welding follow-up in reply to Bus Driver, 11-26-2007 04:37:12
A stick welder is a constant current type power source and a MIG welder is a constant voltage type power source. Entirely different. An Idealarc 250 AC/DC is an excellent machine. I suspect the reason that the old generators were so good was so it was easier to weld. When covered electrodes came along, they kept making really good machines and found that really sound welds could be made. Dave
